Old 06-15-2016, 04:17 AM
Beechy's Avatar
Beechy Beechy is offline
[QUOTE=slenning;634821][QUOTE=Beechy;632279]
Hi Jim thanks for the suggestions, I have included a new drawing showing most of the changes you had mentioned. I did slim down the area above the cluster. You had suggested lifting the top line 3/8" at the cluster end but I thought that it looked too thick when I did that. I used a 1200" radius to finish at 1/4" below the original height at the "glove box" end. I pretty much have all of the programming done to cut the whole top of the dash out of wood. I have cut the front section out based on the new design and I think it looks pretty good! Will post pics when I have a little more.
Thanks again!
BTW I do have about a 36" radius on the top from front to back also.
Steve........sorry it took a while to get back.....those changes take it to another level! You will like the way that light reflects off the curves when it's all done.
There's a lot of man-hours in that dash.....WE ARE ALL IMPRESSED
F
Jim.
Jim Grant
Melbourne, Australia
(Dual citizen)
