Old 06-15-2016, 09:31 AM
slenning's Avatar
slenning slenning is offline
Fabricated a new "speaker" shelf and got that welded in
Steve
70 Camaro - in process https://lateral-g.net/forums/showthread.php4?t=50636
69 Camaro LS7/T56 https://lateral-g.net/members/lenning/
69 Camaro SS396/350hp
64 Chevelle - patiently waiting
2014 Z28 Ashen Gray
2010 Camaro 2SS/RS Black w/White stripes (wife's car)
2015 SS (the 4 door one) Wife's other car
Old 06-15-2016, 09:36 AM
slenning's Avatar
got the down bars made and installed to tie the cage to the subframe, also you can see the tie down brackets we made welded to the front crossmember
Was trying to decide how I wanted to mount the IIMuch fuel and rear end vents and decided to cut a crossmember in similar to the DSE piece on my 69 that the shocks mount to. Used 12 Guage and it welds to the frame rails at each end and provides a flat spot to mount the vents and probably the JRI shock canisters.
Steve
2014 Z28 Ashen Gray
syborg tt's Avatar
Steve that dash is going to look awesome. !!!!
marty-mj
Old 06-15-2016, 09:50 AM
slenning's Avatar
Thanks Marty!! man I hope so
Steve
2014 Z28 Ashen Gray
Old 06-15-2016, 09:57 AM
slenning's Avatar
Two more pics for today! I got these from Schwartz Performance, Sportster CS with suede inserts, Absolutely love them Thanks a lot Dale for the great service!!!
Steve
2014 Z28 Ashen Gray
Old 06-15-2016, 10:36 AM
syborg tt's Avatar
Steve we are no longer friends as you have my seats !!!!!
marty-mj
Old 06-15-2016, 08:27 PM
Awesome updates, Steve. I'm impressed you're able to keep your fingernails clean and polished while building such a badass car.
Old 06-16-2016, 03:03 AM
71RS/SS396's Avatar
Hi Tim 8 quart tank and yes on the GM dry sump
Same setup as my 69 and have been very happy with that.
I don't know what your planned use of the car is but if you plan on any road course action you're asking for trouble with that small of a tank. You should use at least a 10 qt. tank. I started out with a 2 gallon in mine in the beginning and ultimately killed the bearings from starvation and aeration of the oil.
Old 06-16-2016, 05:18 AM
slenning's Avatar
Thanks for noticing Trey, I really try to keep them looking nice!!!
You had me going for a minute till I looked back at my own pics
Steve
2014 Z28 Ashen Gray
Old 06-16-2016, 05:24 AM
slenning's Avatar
Thanks for the info Tim!! I definitely plan on road course use, what did you end up with for a tank? I don't have room for a bigger tank in the cowl area where I have the tank now but I have thought about modifying the tank with a bump out on the lower section like Stielow does.
Steve
2014 Z28 Ashen Gray
