Old 06-22-2016, 03:29 PM
flatoutz flatoutz is offline
Jay,
When installing the system on the backing plate.Are you cutting the axle tube flush with the flange and what size are those bolts?
Mike,
Old 06-22-2016, 08:24 PM
MillerBuilt's Avatar
MillerBuilt MillerBuilt is offline
Default 12 Bolt Kit - Flange/End Prep
Originally Posted by flatoutz View Post
Jay,
Mike,
Hi Mike,
Hope this helps. I have pictured below the required prep and can be done with basic hand tools, obviously you can utilize many different power tools to accomplish the same thing in a matter of minutes. For purposes of illustration I prepared my end in a vise, however this work can be done exactly the same while installed under your car.Oh, the adaptor bolts, or optional ARP studs are 3/8"....
With your existing axles & brakes removed......
Place a rag or similar inside the axle tube to keep debris from entering while performing the prep work
Cut excess axle tube at edge of factory parking brake dust shield register
Tube end removed. The remaining factory dust shield register will now locate the C6/C7 Adaptor centric to the diff/axle tube
Clean up cut with file
Chuck up the included step-bit into your powered or cordless drill
A few squirts of WD-40 at each of the (4) holes
With included step bit, proceed to drill out each existing 3/8" hole to 1/2". These are now ready to accept the 1/2" bosses that protrude from the C6/C7 Adaptor that help locate/strengthen the system
That's it, you are now ready to install your kit!
Let me know if you have any other questions.
Jay
Old 06-23-2016, 05:50 AM
Jay,
Thanks again for the info.The photos are helpful.My only concern with your bolt on system is the load bearing on those four mounting bolts.
Mike,
Old 06-23-2016, 07:14 AM
Jay,
Mike,
Mike,
No need for concern as the C6/C7 Billet Flange actually indexes onto the remaining portion of the factory park brake dust shield register. By doing this the mounting hardware is simply used for clamping force (tension), and will not experience shear force. In addition, the 1/2" threaded bosses that protrude off the C6/C7 Billet Flange are the icing on the cake so to speak as they further enforce this.
Great questions and keep them coming !
Jay
Old 07-02-2016, 02:14 PM
Default In Stock!
These kits are in stock! See original post for details/pricing.
https://lateral-g.net/forums/showthread.php4?t=52854
Please do not hesitate to ask question!
Old 07-28-2016, 09:48 AM
98ssnova's Avatar
98ssnova 98ssnova is offline
So that install is awesome this is on my list!!!!
Old 08-06-2016, 11:56 AM
Default FREE Shipping & PayPal This Weekend!!
FREE Shipping & PayPal This Weekend!! (8/6/16 & 8/7/16 - "lower 48" states only)
Old 08-16-2016, 09:45 AM
csouth csouth is offline
Great product! WIsh this was around when I bought my Moser floater, would have savedme lots of time....
Big dreams, small pockets....
Chris--
'72 Cutlass S LS2/4L70E
Rushforth Wheels, SC&C, ATS, Street Rod Designs, Holley EFI
Project Motor City Madness
Old 08-25-2016, 09:41 PM
nyciti nyciti is offline
No provisions for ABS?
Old 08-26-2016, 02:24 AM
Pretty sure that the hub has the sensor mounts in them .....and let's be honest who beside steilow is actually running abs...people talk about doing it but never do
