Old 07-18-2016, 06:53 AM
Just touching on this, do you need to reference the speed? If it's PWM, just have it turn down as it approaches desired temp. As speed increases, temp will drop and the fans will as well without needing to reference the VSS.
Just a thought.
William
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
Old 07-19-2016, 04:52 PM
Tony V Tony V is offline
Just a thought.
William
I was going to control the fan speed with CTS and Speed but getting a speed signal to the HP wasn't in my scope. right now its working based on temp.... a simple straight line slope as its getting hotter the PWM % increases.
Old 10-02-2016, 10:49 AM
andrewb70's Avatar
Just a thought.
William
I've been using VSS as part of my fan control strategy, but from experience I can say that it isn't really needed. Personally if a car has A/C it makes more sense to do CTS vs. A/C pressure. If no A/C then you can do CTS vs. engine oil temp.
Andrew
Old 04-13-2017, 09:31 PM
Larry R's Avatar
Larry R Larry R is offline
Andrew
How does one set up a CTS vs A/C pressure? Where and how do you get A/C pressure. My car has a trinary switch is that used? I do have a VSS in my car but I am intrigued by the idea of using A/C pressure.
Thanks, Larry
Old 04-14-2017, 09:31 AM
dontlifttoshift's Avatar
We just did a Dominator in a 32 and we used a holley 500 PSI pressure transducer. This allowed us to skip the binary switch and the gm pressure sensor and do it with one sensor. We control the pwm fan and control compressor clutch engagement (high and low pressure cut off) through the ecm.
So far, it works.
Donny
Old 04-14-2017, 09:22 PM
Larry R's Avatar
Interesting concept, and since it works, worth considering. I do like the idea of having the fans either go off or be drastically slowed down at speeds above, say, 55 to 60 mph. I'm new to the PWM idea so I have a lot to learn. Thanks.
Old 04-16-2017, 07:19 AM
Larry R's Avatar
So far, it works.
What threads does the Holley 500PSI transducer have? Thanks, Larry
Old 04-16-2017, 08:14 AM
andrewb70's Avatar
One eighth NPT.
Andrew
