Old 07-19-2016, 06:58 AM
Blake Foster's Avatar
I told you he would have a better explanation then mine
Blake Foster
www.speedtechperformance.com
Old 07-19-2016, 09:09 AM
Hate to read the long answer
Old 07-20-2016, 09:39 PM
David Pozzi's Avatar
I drove the Art Morrison test Camaro with IRS when it first came out and just loved it. The lower unsprung weight helped the car ride over track bumps and undulations without being as upset. I translate that into increased car stability and feel, which is what I was looking for, and I absolutely love the ride on the street, - just dial the shocks down. It's also a big improvement for street cars, which is the target market for Art Morrison, and Mary has proven it works for autocrossing, she's not that aggressive a driver on a road course but the car has felt great there. The downside is it takes some smarts to change alignment settings on it. We tend to not mess with it once we got it set well.
Prior to this I was thinking of swapping a Corvette IRS into my 67 Camaro but I was worried about how much build time it would eat up designing and fabricating it, and would it break? What needed beefing up?
When the Art Morrison IRS came out, I saw right away it is much stronger than the Corvette unit all the way through, needed no beef up, the lower links links are Johnny joints, and it has a Strange Dana 60 third member, durability was a big factor for me in selecting this IRS, plus it was already engineered.
http://www.PozziRacing.com
Old 07-21-2016, 09:24 AM
Ron Sutton's Avatar
I think you nailed the summary of the IRS. It provides a great ride, good tight corner turning (autocross). You just want to pick one that is built strong & the geometry has been worked out ... or be prepared to work it out yourself. You also need to be prepared to write the large check. LOL
I remember talking to Mary initially and the set-up had a bit too much rear steer for her tastes. Once they/you dialed that down, she loved it. And of course was & is fast with it, winning often.
Ron Sutton Race Technology
Old 07-21-2016, 10:03 AM
I made a mistake early on. The first thing I did after installing it was add more neg camber. This changed the rear clocking (caster) of the rear hubs, lowering the toe link rod end height. From then on, the Art Morrison recommended cam settings we had for toe steer were off, and it was getting a lot more toe out than expected. Also Perf Trends software will not correctly model this suspension. We get numbers, but they are wrong as far as roll center height.
Old 11-23-2016, 08:24 AM
Erickson Performan's Avatar
Erickson Performan Erickson Performan is offline
HAHAHA I would love to read the long answer. Ron you are a wealth of knowledge.
