Old 06-06-2016, 09:35 PM
LanceL LanceL is offline
Great to know! Thanks a lot
Old 06-07-2016, 07:01 PM
Centerforce's Avatar
Centerforce Centerforce is offline
The wheel setup looks killer tucked nicely in those fenders!
Old 07-27-2016, 07:52 AM
jeds jeds is offline
Dailey 3-stage dry sump. The pump mounts directly to the pan. Pan depth is only about 1 3/4 inches!
It's almost too pretty to hide inside an engine bay. I might just display it on my coffee table instead.
Old 07-27-2016, 08:11 AM
Dave95z28 Dave95z28 is offline
Did you get the dash installed? How did it turn out?
Dave
Old 07-27-2016, 08:30 AM
In short...the dash does not fit well.
* The column cutout is too tight.
* The left side fitment where the insert wraps around the edge of the dash is way too tight.
* The left side of the insert is too long. I even tried trimming the bottom edge but still it didn't fit correctly.
* It seemed that no matter how it was installed, the insert would not sit straight in the dash.
I just can't seem to get it to fit.
Old 07-27-2016, 09:10 AM
98ssnova's Avatar
98ssnova 98ssnova is offline
That sucks about the dash do you think you can build you own? Maybe use this as a rough guide?
Old 07-28-2016, 05:51 PM
ebncrdr ebncrdr is offline
Do you have pics? I've bought 2 of these and they fit well enough with a little pushing and pulling.
Old 07-28-2016, 09:15 PM
The left side seems to stick out too far. I can't push it in because the insert hits the dash framework. You can see this interference in the last image.
The right side seems to not fit in the upper right corner. The flange that bends in on the bottom of the insert is clamped all the way across. I don't see how I could close the gap with out a significant bend in that lower flange.
Am I missing something here?
Old 01-25-2017, 09:00 AM
Wegner setup and Dailey pan/pump installed.
Old 01-25-2017, 09:03 AM
When I got the dry-sump pump mounted and attempted to install the motor, the pump ended up wanting to occupy the same space as the motor mount. I knew interference was inevitable...
I've been wanting to push the motor back for a while now. This situation finally gave me the excuse to do it.
The motor got pushed back about 12.5" from the existing motor mounts.
The new motor location is setup to give me just enough room to install/remove the dry-sump pump belt.
