Old 07-23-2016, 01:53 PM
kwhizz's Avatar
kwhizz kwhizz is offline
Still very Hot and Humid here.......Got the firewall plate for the A/C installed......Got to get some more insulation wrap to finish it off.........then I decided to get the dash out so I could take it into the house (A/C) and get the Dakota Digital gauges installed.......I'll leave the dash out till I finish all the internal A/C hook ups and get the Dakota Digital control modules wired and installed.......Working room......
Sheesh.........Look at all the Dust........
Don't worry Keith, I'll clean it...............LOL
Old 07-23-2016, 09:19 PM
Zoomin Zoomin is offline
man, what a great starting point for a project!
1964 Lemans
1966 Skylark
1969 Camaro
Old 07-24-2016, 10:05 AM
Sonar Chief's Avatar
Cool
I was thinking the same thing ... I'd take a little DUST over RUST any day
Old 07-24-2016, 03:53 PM
kwhizz's Avatar
Was in the Garage today for only about a 1/2 hour.........put a header on to see if the stock oil dipstick was going to work........Fits perfect... :bigthumbup:..........Then put the adaptor plates on that the "B" body cars need........should have the engine in Tuesday/ Wednesday....
Old 07-25-2016, 06:52 PM
kwhizz's Avatar
Getting closer........But........I found more "Dirt" !!!........Sheesh.......Does it ever end...In these "B" body LS swap's......the rear trans cross member needs to get moved back 2 1/4".....so.....I cut the frame mounts out and will re-weld them in position as required upon install..........Got the engine mounts installed and also the engine and transmission harnesses........Next......Get the drivetrain in the Car......Here are some Pic's
The Radiator showed up also
Old 07-25-2016, 07:25 PM
Jon69RagTop Jon69RagTop is offline
Default Keep the updates rolling Ken
I always enjoy checking in n the progress.
Old 07-26-2016, 09:23 AM
QuickTrick's Avatar
QuickTrick QuickTrick is offline
Following. Can't wait to see more progress!
QuickTrickers
Ms QuickTrick aka Tess
QuickTrick Media aka Gil
Old 07-27-2016, 05:22 PM
kwhizz's Avatar
Moved a couple steps forward today........Got the trans cross member frame mounts cut off the frame and the frame cleaned up and ready for welding them in their new position.....and Dave and Gary stopped over to help get the engine in the car.........Got it in and installed the trans cross member , then got everything in position and Brent was there to weld the frame mounts in their new position......started to separate out all the wires and got the Headers installed........Moving along..........
Old 07-28-2016, 08:51 PM
That Mac's lift plate works slick, I love mine. Did you guys bend up that frame mount part for the trans crossmember, nice job! Nice progress guys.
Old 07-29-2016, 05:26 AM
kwhizz's Avatar
No......Those were the ones I cut off the frame........Just Glass Beaded them and re-welded.........
