Old 07-29-2016, 08:44 PM
randy randy is offline
why can't you just give the light constant power and hook the ground to the check engine light wire? Thats what i did
Old 07-30-2016, 04:22 AM
130fe 130fe is offline
Post
Don, just curious. The picture I saw on New Vintage's website showed a CEL in the right side gauge. Why not use the one already built in? Are you 100% sure that the CEL requires the POS signal? Just seems weird that the industry standard is a Neg signal from the PCM and New Vintage is totally different. Just seems like alot of trouble to go through for the light to work.
http://www.newvintageusa.com/images/69-set-lit.jpg
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 07-30-2016, 04:30 AM
DT69Cam DT69Cam is offline
Yep, that's the one. It calls for 12V positive.
69 Camaro Convertible (LS3/TKO in the works)
Old 07-30-2016, 04:32 AM
dhutton dhutton is offline
For whatever reason the gauge wants a positive drive for all the indicators. Both LED pins are not brought out, only the positive side as far as I know. Why they didn't do their homework is a bit of a mystery. There may even be a controller between the input signals and the LED's.
Old 07-30-2016, 04:33 AM
Because you don't have access to both LED pins.
