Old 10-12-2016, 07:15 PM
NLPed NLPed is offline
Default 1963 Ford Falcon
I only just bought this car 5 days ago. After a successful 800+ mile drive from Texas back to Alabama without a hitch, I managed to grenade the motor on a short drive with my wife. Not really sure what happened except that the crankshaft is absolutely broken. So I'm about to build myself a restomod.
Background on the car... I bought from a friend who has owned the car since the mid 90's. It was his mothers before that. He upgraded quite a bit of the car over the 20+ years. 306 HO motor with AODe with 4r70w guts and an 8.8 that is narrowed to fit properly. 65 mustang front suspension with 10" power disc brakes out front with all new pieces and parts.
My plan... TCI front IFS and rear 4-link, Wilwoods front & rear, and best of all...2015 Mustang 2.3L Ecoboost and 6-sp tranny.
Pics of it as I picked it up.
Old 10-12-2016, 07:17 PM
And what happened on the Monday drive.
Old 10-12-2016, 10:41 PM
Good lookin Falcon!
And that sounds like some friend...
Old 10-13-2016, 10:22 PM
craig510's Avatar
craig510 craig510 is offline
That is a great looking hardtop. You might want to check out my build thread if you want any ideas.
https://lateral-g.net/forums/show...=39876&page=22
I am not personally a fan of the MII suspension. It has too steep of a KPI so you cannot optimize it fully.
Old 10-14-2016, 07:06 PM
I actually read your thread. Very informative and I love your car. I don't exactly have your background and certainly don't have access to the equipment you do. Since you mention it, what style/brand front suspension would you suggest? I'm absolutely open to suggestions.
Old 10-14-2016, 08:26 PM
craig510's Avatar
I would go with the Mike Maier Inc stuff up front. More or less bolt in and works great. Lots of brake options for original spindles. Add the ABS power steering box and the front end is dialed.
Old 10-15-2016, 05:17 PM
Worked on getting the hurt motor out today. Motor wouldn't turn over at all..even with a huge breaker bar on the crank bolt. So I peeled all the accessories off and found this.
Old 10-15-2016, 05:20 PM
So after HOURS of beating hammering and beating some more I finally got to this.
And confirmed that the block is junk...
Old 10-15-2016, 09:12 PM
craig510's Avatar
So did the block crack and that allowed the crank to move or did the crank brake and that cracked the block?
How high were you or your buddy reving it? I've got pretty much the same motor in my car and run it to 5900 quite a bit. I would rather not break it right now so maybe I should be more conservative with the rev limiter.
Old 10-15-2016, 09:58 PM
It was me & my wife. We weren't driving the car hard at all. I had just driven the car from Texas back to Alabama without any issues. And I'd enjoyed several high rev passes. I'm really not sure what happened, but I feel like it was the cast crank that gave up the ghost.
