Go Back   Lateral-g Forums > Technical Discussions > How To's, Tips, and Tricks
Old 11-19-2016, 01:04 PM
qtrracer's Avatar
qtrracer qtrracer is offline
Originally Posted by Neil B View Post
I use a degree wheel and a dial indicator on the valve tip with a checking spring installed. I check in 5 degree increments from 10 degrees BTDC to 10 degrees ATDC.
x2. I have a used head gasket for the procedure. I find this method lots easier and more accurate than the clay method.
