Old 11-20-2016, 11:26 AM
rallystyle rallystyle is offline
sheck44 they are designed for there valve covers but i a seen on other sites where people have drilled and tapped there valve covers then bolted on the katech brackets.
1970 El camino
1969 camaro
1996 civic
Old 11-23-2016, 12:03 AM
Nativefx Nativefx is offline
Anyone have a picture of the Katech brackets and coils installed?
Old 11-23-2016, 06:21 PM
randy randy is offline
I made my own boxes and moved them to the subframe. $100 set of wires
$100 coil extension harness
$30 in metal and bolts
Old 11-24-2016, 03:26 PM
Air-bender Air-bender is offline
Check out the 67 Camaro build on here by Dutchboys! Katech valve covers and Katech coil mounts.
Old 11-25-2016, 08:29 AM
gerno's Avatar
gerno gerno is offline
Carbuff is running the Kartech valve covers and coil mounts. I assume he has pics in the TOW build thread or you can PM him for some.
Old 11-25-2016, 04:23 PM
carbuff's Avatar
carbuff carbuff is offline
Here are a couple:
