Old 11-27-2016, 05:22 AM
Z06vette's Avatar
Z06vette Z06vette is offline
I gave up trying to get the E38 to control twin fans. I used the entropy fan controller. It has has an AC trigger wire, and the dip switches let you easily set the on/off temps for each fan. I know this isnt exactly the answer to what you are asking, but its an option. Scott
69 RS LS3/T56
68 firebird vert LS1/4L60E
67 RS LS2/T56
Old 11-27-2016, 11:24 AM
lsuguy's Avatar
lsuguy lsuguy is offline
I found this on a C10 truck forum. It appears that it will work but I am open to comments on this. Worst case is that the fans are powered by more than one relay under some circumstances but I don't think that should be a problem...
I have seen the entropy controller and its a nice setup.
Old 11-27-2016, 01:12 PM
dhutton dhutton is offline
That will work fine. I did the same thing several years ago. I prefer the series/parallel low/high setup, but this will work, just a little noisier in low speed.
