Old 12-05-2016, 02:11 AM
gmc427 gmc427 is offline
cheers, thanks for the info,im a bit confused,how are you able to run so much back space?is your track wider than stock?regards george
Old 12-05-2016, 10:30 AM
califconstruct's Avatar
califconstruct califconstruct is offline
No, still stock. I can tell you that sharp turns are a bit challenging. Tires do rub on the frame a bit on making u-turns. no problem auto crossing on the one time I took it.
Definitely affected my turning radius, but not noticeable on everyday driving.
Don't see it as a problem at all.
Old 12-09-2016, 06:25 PM
So running down the street and KABOOOMM.. adn a whole lotta other racket!!.
LS6 .. apparently this crankshaft pully had a recall and or it was built ****ty, and was known for detonating and screwing up peoples underhood. Well, I was a lucky one. It's back on the road, got a new ATI pully, Had to replace water pump, weld up a hole int he new Stainlessworks Exhaust and change out hoses. Glad it happened close to home. Still looking forward to driving it. Rain = no go!.
Old 12-09-2016, 06:31 PM
Sonar Chief's Avatar
Art ... looking forward to a ride when you get back from Sac!!
Old 12-09-2016, 07:35 PM
glassman's Avatar
glassman glassman is offline
Dayum!!!!
Mike
Old 12-09-2016, 08:47 PM
Mikael A Mikael A is offline
That's crazy....you are lucky nothing serious happened.
Mike a
Old 12-09-2016, 09:19 PM
Zoomin Zoomin is offline
Dayummm
1964 Lemans
1966 Skylark
1969 Camaro
Old 06-23-2017, 05:40 AM
sorry ,didnt relise you were running tru turn as well,regards
Old 06-23-2017, 02:16 PM
Hi,
No, no true-turn on this front clip. Was planning on it with the previous front clip i built, but ended up getting this LS motor/Tranny set up with DSE parts.
Actually sold that front clip that had the tru-turn.
Art
Old 06-24-2017, 10:10 PM
stock spindles?tie rod ends/steering arms dont foul inside of rim?regards
