Old 11-24-2016, 08:21 PM
califconstruct's Avatar
califconstruct califconstruct is offline
Originally Posted by Panteracer View Post
Car looks great.. good to see you are out
running it... Hope to see you at Marina and Crows
next year
Bob
Thank's Bob, looking forward to it.
Originally Posted by preston View Post
How is the NRG steering wheel quick release ? Most QR's I've used always have a little play in them, how tight is the NRG ?
(If you like it do you know which model you are using ? )
I like it so far, no play, slop or movement noticed. Clips on tight. I like the shallowness. I'll look up the model and get back to you!.. =)
Originally Posted by Mikael A View Post
so cool...love the wheels.
Thank's , their growing on me... I actually expected to get Forgeline's other Transperent gold.. but I got this Transparent "bronze" gold. Still on the fence with the color. Expected the brighter.. yellow version.
Old 11-25-2016, 12:14 AM
gmc427 gmc427 is offline
hi ,are,you running 265,35,18s on the front?whats your set up?thanks in advance george
Old 11-30-2016, 03:36 PM
Default tire/wheel size
Hey George,
Yes, 265/35r18 front 6 3/8 Backspacing on DSE A-arms, stock sub frame.
Speed Kit3
on DSE A-arms, stock sub frame. with coil over shock tower relocation.
315/30r18 rear 18 x 12" wheel
Old 12-05-2016, 12:11 AM
cheers, thanks for the info,im a bit confused,how are you able to run so much back space?is your track wider than stock?regards george
Old 12-05-2016, 08:30 AM
No, still stock. I can tell you that sharp turns are a bit challenging. Tires do rub on the frame a bit on making u-turns. no problem auto crossing on the one time I took it.
Definitely affected my turning radius, but not noticeable on everyday driving.
Don't see it as a problem at all.
Old 12-09-2016, 04:25 PM
So running down the street and KABOOOMM.. adn a whole lotta other racket!!.
LS6 .. apparently this crankshaft pully had a recall and or it was built ****ty, and was known for detonating and screwing up peoples underhood. Well, I was a lucky one. It's back on the road, got a new ATI pully, Had to replace water pump, weld up a hole int he new Stainlessworks Exhaust and change out hoses. Glad it happened close to home. Still looking forward to driving it. Rain = no go!.
Old 12-09-2016, 04:31 PM
Sonar Chief's Avatar
Art ... looking forward to a ride when you get back from Sac!!
Old 12-09-2016, 05:35 PM
glassman's Avatar
glassman glassman is offline
Dayum!!!!
Mike
Old 12-09-2016, 06:47 PM
Mikael A Mikael A is offline
That's crazy....you are lucky nothing serious happened.
Mike a
Old 12-09-2016, 07:19 PM
Zoomin Zoomin is offline
Dayummm
1964 Lemans
1966 Skylark
1969 Camaro
