Old 12-28-2016, 07:55 PM
jonathonar89 jonathonar89 is offline
Here's some recent news for you guys who think BS3 is outdated...
Monday, August 1st, 2016
BigComm Pro is the new BS3 software application to enable high fidelity tuning of BS3 Engine Management systems. This, combined with MegaLogViewer BigStuff3 and new Android interfaces make the BigComm Pro software suite the most complete tuning package available.
Also, here's a link to see some of the new software...
http://bigcommpro.com/about
Here's some results from Big Stuff 3 users in the racing scene the past two months. I have pulled this from the BS3 Facebook page. Check out the bold letters below for fastest street car record....
No Mercy 7 (10/9)
Shawn Fisher - X275 Winner!
Joel Greathouse - Ultimate Street Runner-up!
ODR - Phil Hines Runner-up!
NHRA Div 2 (10/16)
Al Ackerman - Comp Eliminator Winner! 2 in a row!
NMCA West - World Finals (10/16)
Greg Seth-Hunter - ProMod Winner! NMCA West ProMod Champion!
Ryan Jones - Limited Street Runner-up!
Anthony Smith - Outlaw 8.5 Winner! NMCA West Outlaw 8.5 Champion!
World Cup Finals (11/4)
Mike Modeste - Radial vs. Modified Winner! Check out Mike's Winner Circle picture and video
Orlando World Street Nationals XXIII (11/13)
John Carinci - Outlaw 10.5 vs. PDR #1 Qlf'r & Winner!
Charles Hull - Street Outlaw #1 Qlf'r & Winner!
Chris Lancaster - Ultra Street #1 Qlf'r & Winner!
Jeff Lutz - Lowered Fastest Street Car record to 5.85 @ 250 mph! Check out Jeff's awesome 5.87 & 251mph pass
NHRA Auto Club Finals @ Pomona (11/13)
Bill Skillman - Super Stock Runner-up!
SCSN @ LasVegas (11/20)
Mike Bowman - ProMod Winner! Check out Mike's winning final run video
Norman Chang - XDR Winner & top speed!
Eric Gustafson - XDR Runner-up & low ET!
Roger Holder - RVW Runner-up & low ET!
Greg Seth-Hunter - Outlaw 10.5 #1 Qlf'r!
Old 12-28-2016, 08:31 PM
andrewb70's Avatar
No Mercy 7 (10/9)
NHRA Div 2 (10/16)
Thanks for a cut and paste.
Holley is used I all pro-stock cars. Do you have a car with BS3?
Andrew
Old 12-29-2016, 04:03 AM
TurboChris TurboChris is offline
Andrew
Not to discredit you or holley but it's mandated to run the holley hp as the only efi for use in pro stock, part number 554-129. It's a specific hp ecu and I can't find it for sale even on holley's website, probably have to buy it right from the nhra so they can get there markup on it.
I know you weren't quoting me but yes I do run a bs3 in my street/strip car, 16 injectors, lots of street time and e85 fueled for both street and track.
The bs3 is an excellent and easy to use main stream high end ecu with a better than oem harness and connector set. As Jon said it's only gotten better since the new software was release this past year.
I wouldn't discount it as being an excellent system to pick up used at a good value on the cheap.
Nothing wrong with a holley system as well, depending on one's needs the hp and dominator are both excellent values. Just be careful with that mini usb port, the holley ecu's are potted and can not be repaired.
My street car, 16 120lb injectors controlled by bs3.
Old 12-29-2016, 05:36 AM
Andrew
No Andrew, I have a Megasquirt 2 I'm working on at the moment. It controls, fuel, timing and has some additional features like boost/nitrous control but I don't need the extras to build an efi system using TBI and HEI on my 4 speed Poncho. I had FAST XFI 2.0 but sold it because it was pretty much overkill for what I'm building and I wanted to build out my whole system. In my case I simply don't need Megasquirt 3, MS3-Pro, Holley Dominator, or the XFI 2.0 like I used to have. You've seen my stuff when I had the FAST and we've exchanged conversation on efi subjects on the Pro-Touring forum. My profile over there is F-Body International.
I used to glorify the Holley as well, but after going over efi topics with my friends and being on the forums, I have become less and less impressed by Holley efi. I'm not saying it's bad, but I've just become less impressed. In the end most efi systems generally do the same thing. You really have to know what you're talking about to say one is better than the other. I personally would rather have an ecu that is serviceable and also able to upgrade. For instance, with FAST, you can start with a base XFI unit and add traction control, logging, etc. With Holley you're stuck with what you have if you buy the HP/Terminator box and it can't be upgraded to the Dominator.
My Megasquirt MS2 carb-to-efi kit was around $600 and came in at about $750 once I added my Innovate LC-2 wideband setup...Black Friday sale at www.diyautotune.com
Old 04-17-2017, 09:38 AM
gnx7's Avatar
gnx7 gnx7 is offline
A little more info for those shopping EFI systems.... at PRI the MS3Pro Ultimate system was released. This bridges the price gap essentially between the Holley HP which has lesser I/O ports and the Dominator which has a ton of I/O's.
The MS3Pro Ultimate in essence does what the Holley Dominator can do.... at just around the Holley HP price. The Holley systems while not included in their package when you order it.... need (2) 0-100psi pressure sensors for oil and fuel pressure which add another $200+.
I run the HP in n/a cars and forced induction cars can benefit more from running the Dominator setup for boost by gear/time etc. Had the MS3 Pro been available when I bought my systems.... I would've tried that for sure. Plus it is 100% made in the USA with a LIFETIME warranty. They have harnesses premade for the 24x and 58x LSx applications.
https://www.diyautotune.com/product/...gement-system/
Old 04-21-2017, 02:51 PM
supremeefi supremeefi is offline
There are a few systems out there like the MS3 that are capable of the same things at less cost than a Dominator. The latest AEM Infinity is one of those as well.
Mark
Engine builder and tuner.
