Old 12-30-2016, 06:33 PM
syborg tt's Avatar
Subscribed and love the 1st post telling the history of the car and I'm looking forward to watching the rest of this build.
Sent from my iPad using Tapatalk
marty-mj
Old 01-13-2017, 01:35 PM
V8TV's Avatar
V8TV V8TV is offline
Originally Posted by gofastwclass View Post
Always amazing what you find lurking beneath the paint on an otherwise nice looking car! You guys are doing a good job of making it solid again.
Thank you sir!
This one has a cool history, we're glad to be a part of the next chapter! Thanks Marty!
Kevin Oeste
V8 Speed and Resto Shop
V8TV
Muscle Car Of The Week
V8 Radio Podcast
All about us:
https://www.v8speedshop.com
V8TV's Avatar
The old floor piece came out in one large section.
The new YearOne center trunk floor section is a very faithful reproduction on the original floor.
Adam chose to remove the trunk floor supports at this point, and transfer them to the new YearOne floor section outside the car. This would be a quicker approach than having to weld them in under the car.
Then, the new YearOne panel was trimmed to match the size of the hole left in the car.
Adam installed the long arms on the HTP spot welder, cleaned the e-coat, sprayed the bare steel with HTP Weld Through Primer, and positioned the original trunk floor supports on the new panel. Then he spot welded the panels together, leaving a factory original appearing weld process.
Kevin Oeste
V8TV
V8 Radio Podcast
All about us:
Old 01-13-2017, 01:40 PM
V8TV's Avatar
The new section was then positioned in the car and held in place with some Eastwood panel clamps to keep it flush. The panel was welded in with a long series of MIG tack welds, and the welds were then ground smooth. The result is a virtually undetectable repair.
This photo is from a little later when we were prepping the bottom of the car for epoxy and coating, but you can see the bottom of the floor job clearly.
Kevin Oeste
V8TV
V8 Radio Podcast
All about us:
Old 01-15-2017, 06:41 AM
gofastwclass gofastwclass is offline
Excellent work.
I build my own junk...
Old 02-01-2017, 03:12 PM
V8TV's Avatar
Excellent work.
Thank you sir!
Kevin Oeste
V8TV
V8 Radio Podcast
All about us:
Old 02-01-2017, 03:16 PM
V8TV's Avatar
The COMP Camaro is rolled into the paint booth where the body shell is cleaned and Axalta epoxy primer is applied over the areas of the car where new metal was installed. This will provide corrosion resistance as well as to be a strong foundation for future topcoats or body filler.
Kevin Oeste
V8TV
V8 Radio Podcast
All about us:
