Old 01-06-2017, 08:00 PM
JMitch19's Avatar
JMitch19 JMitch19 is offline
Originally Posted by DT69Cam View Post
Thank you again! Do you know if the GMPP harness will plug into that pedal ? I like that pedal better than the one that comes with the GMPP harness kit.
I would assume so. If you have a schematic for the gmpp harness I could check for you.
Jason Mitchell
1971 Camaro 416 LT1 Project
Old 01-07-2017, 07:10 AM
DT69Cam DT69Cam is offline
Unfortunately all I have is the manual:
http://www.chevrolet.com/content/dam...d-19259293.pdf
69 Camaro Convertible (LS3/TKO in the works)
Old 01-07-2017, 10:21 AM
JMitch19's Avatar
The ECM is pinned the same as a factory LSA engine. I'd assume the throttle pedal would be no different.
Jason Mitchell
Old 01-07-2017, 05:07 PM
Thanks!!!
