Old 01-12-2017, 04:42 PM
samckitt's Avatar
samckitt samckitt is offline
The part of the thermostat that reacts to the temperature is on the back side of the "valve" away from the cooler fluid. The engine side is hotter & opens up to allow cool fluid through, it closes if temperature drops, recirculating warmer fluid from the engine back through it. I would say you have a bad thermostat, but you say you are on the 3rd or 4th one. So i'm confused too.
Scot
86 Monte SS
LS2/T56 Magnum
Old 01-12-2017, 04:50 PM
dhutton dhutton is offline
Is it possible to install an LS thermostat backwards?
Old 01-12-2017, 04:56 PM
samckitt's Avatar
No, the metal coil that controls the valve wont fit under the housing if backwards.
Scot
86 Monte SS
LS2/T56 Magnum
Old 01-12-2017, 08:43 PM
yukio yukio is offline
Ok, thanks for the replys.
Ill try some other stuff tomorrow.
I am still thinking that when the thermostat opens, cold water get to the "temp sensing" side of the thermostat, which in turns closes the thermostat.
Does the backside of the thermostat (passage to the heater) need alot of circulation of hot water to get the thermostat working properly?
Old 01-12-2017, 09:44 PM
Chad-1stGen's Avatar
Chad-1stGen Chad-1stGen is offline
I don't think this is it. The thermostat is more efficient if you have your heater hoses flowing full time as opposed to a shutoff valve in them. This is how all LS motors work from the factory. However, plenty of people run the ports blocked without any trouble.
I suspect air in the system. Where does the steam vent line go? Next time the car is fully warmed up and you are sitting still try reving it up above 2,500 rpm for 30+ seconds. If the temp drops then you have air trapped in the system.
Autocross and Track blog
Lots of autocross & track day videos of my car: https://www.youtube.com/user/TheDude023
Old 01-13-2017, 04:18 AM
71RS/SS396's Avatar
How are the fans controlled? What's the temp when you're standing still? Why a 160* thermostat?
Old 01-13-2017, 04:53 AM
Where did you connect the steam vent?
Old 01-13-2017, 04:58 AM
If this was the case every LS out there would have this problem. They don't...
Old 01-13-2017, 05:19 AM
randy randy is offline
fans wired backwards so its pushing instead of pulling?
Air in the system would be my guess if the fans are operating the correct way.
Old 01-13-2017, 03:51 PM
Z06vette's Avatar
Z06vette Z06vette is offline
What temp is the car running at when standing still? What are your fan on/off temps set at? I find that air gets trapped in these setups often when firt installing everything or when the system has been drained. If one hose is cold, its not circulating,obviously. Doubt 3 thermostats are bad. Do you recall how much coolant you poured in? If the motor was bone dry initially, it will take 2.5-3 gallons to fill. To help purge the system, I found that driving the car to get it up to temp- maybe a couple miles. Then park it overnight, removing the cap after it cools. Most times, the next morning I can add anywhere from 1/2 to 3/4 gal of coolant. Keep us posted
69 RS LS3/T56
68 firebird vert LS1/4L60E
67 RS LS2/T56
