Old 01-31-2017, 07:15 PM
Hydratech®'s Avatar
Supporting Manufacturer
HydratechBraking.com
Thumbs up Bringing parts back from the dead
In today's modern LS world, I actually do wish that I could afford to put the latest LT4 supercharged direct injected Vette engine into my build instead of the 45 year old dinosaur Olds 488 stroker
The good news is that I am in discussions about having the Olds roller cam thrust plate and the Olds oil filter relocation plate reproduced:
http://classicoldsmobile.com/forums/...ust-plate.html
If there is anybody else out there that may be interested in these two parts, please chime in either here or at the Olds 'site! Bringing parts back out of extinction!
Founder / Master Engineer
Hydratech Braking Systems ®
www.hydratechbraking.com
Old 05-28-2017, 08:17 PM
Hydratech®'s Avatar
Talking Back From Extinction Now :)~
I have finally reproduced the factory Oldsmobile camshaft thrust plate!
http://www.hydratechbraking.com/imag...hrustplate.JPG
http://www.hydratechbraking.com/imag...rustplate2.JPG
After a TON of research into materials, and very extensive testing and study of the original part, I decided to have these run in an expensive heavy duty bearing grade bronze material. I also changed the design a bit, as the factory thrust plate provided a whopping .030" of end play, which I modified in our design down to .010" end play. The OEM version was made out of an annealed steel - Rockwell hardness testing was surprisingly soft at 38. These will fit all standard Oldsmobile engines with any type of camshaft, and every timing chain design I have tested - total control of camshaft end play = no timing light bouncing around, overall smoother engine run as a result. Remember, this is not something I came up with, this is a very rare Oldsmobile "million dollar engineering" part that unfortunately went extinct about 20 years ago that I have now very carefully reproduced. Original part number GM 22527023.
I have eleven of these currently in stock as of this writing, because I haven't had time to even post about them yet, much less market them. Let me know if you are interested - $105 plus UPS ground shipping. If / when these do go into regular production, costs may come down with larger production runs. And yes, the stock non roller oil gallery plugs work just fine to mount it. Private message or e-mail if interested at the e-mail address below. Please don't call the standard Hydratech phone, as Jim is not aware of this product (essentially no idea).
NOTE: WILL NOT FIT THE 403 DUE TO REVISED OIL GALLERY LOCATIONS
Paul M. Clark
[email protected] <--------
