Old 02-12-2017, 06:05 PM
randy randy is offline
Are they full height body bushings?
Old 02-13-2017, 10:57 AM
Blake Foster's Avatar
you got this all figured out this morning i trust? Jeremy was getting you some info on the mod to make it work if i heard correctly.
Sorry for the confusion.
Blake Foster
www.speedtechperformance.com
Old 02-13-2017, 01:13 PM
Build-It-Break-it's Avatar
What mod is there to make the column fit Blake?
Ahmad B
Old 02-13-2017, 01:58 PM
We have a specific part number from ididit to use # 11206800XX for 67-68 and 15207900xx for the 69. These have 1" 48 spline ends that match up to the steering shaft kit . Then we move it up (vertically) about 1.5" at the firewall plate, just enought for the ujoint to clear the frame. We end up adding some material to the bottom of the factory firewall clamp/ mount plate and trimming off the top. if your doing a different set up with some other arrangement then you may have more options.
Blake Foster
The Following User Says Thank You to Blake Foster For This Useful Post:
srode1 (09-08-2021)
