Old 02-21-2017, 08:32 AM
minendrews68 minendrews68 is offline
Guys, I'm sorry! I didn't notice the reply's to this post. I will get pics and where I bought the items and post them for you. Again, sorry I took so long.
Old 02-21-2017, 11:11 AM
Ketzer's Avatar
Ketzer Ketzer is offline
Don't worry about that, just roll down here and do mine and I'll take pics as you work...!! ( j/k )
Old 02-24-2017, 07:42 AM
Your in Eads? Not that far away, maybe a hours drive, I'm in Jonesboro, AR
Old 02-24-2017, 05:10 PM
Build-It-Break-it's Avatar
The part to build your own e-stopp is called a linear actuator with a 2"stroke. The one e-stopp uses has a 600lb pull rate I believe and the ones that can be found cheaper are about 250lb which I think would be plenty. They use them on handicap vehicles.
All the parts are sold on ebay including the wiring. You'll just have to build a box and run the cable/ set tension which you would have to do anyways with the e-stopp
I'm going to put one together myself as well and mount it in the trunk by the rear seat.
Ahmad B
Old 02-27-2017, 01:47 PM
vstol vstol is offline
following this one
