Old 03-11-2017, 09:15 AM
wiedemab's Avatar
wiedemab wiedemab is offline
First we lightly folded the skin edges over and test fitted it to the car. This allowed up to adjust the skin on the shell. You would be surprised at how they will twist and move around - - if you aren't careful you can make a mess. Once we had it where we wanted it (these Dynacorn skins fit pretty damn well) - I tacked it in a couple of spots, took it back off, hammer and dollied the rest of the skin and welded it on.
I have to say - it's invaluable having the old man around (he's skinned who knows how many doors in his life) - lots of little tricks to be learned. I consider myself a fairly intelligent person, but there is no substitute for good ole experience! Action photo of Dad!
Door back on and adjusted to the quarter and fender....next is start working the gaps. (I have basically the same pics of the other side, but for conciseness will spare the redundancy)
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 03-11-2017, 09:21 AM
wiedemab's Avatar
Gap was wide at the top, so I split the quarter and moved it forward a bit.
Quarter stuck out from the door at the top (shape a little off too). The rest of the door to quarter lined up well, so I split the jam and reshaped it.
The top of the quarter ran a little uphill toward the front of the car. I split it and lined it up so that the molding would line up properly without too much adjusting/shimming.
There we go - -much better!
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 03-11-2017, 09:31 AM
wiedemab's Avatar
The only other thing that I've gotten done recently was to work on buttoning up the tail-panel and tail-light areas. I welded up the factory lead seams with silicon-bronze (same as I did at the roof to quarter seam. I still have a little bit of work to do on the tail-light area and then gap the decklid.
Slowly, but surely making progress. One of these years it'll be on the road.
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 03-11-2017, 09:58 AM
SlowProgress's Avatar
Thanks for sticking with this project. Love that your saving another one. You are lucky your dad has the skills to help out as well and your metal work is great, something you will have your whole life. For some reason I never subscribed but I fixed that today. Stay motivated!
Old 03-12-2017, 03:45 AM
HEEP's Avatar
HEEP HEEP is offline
[QUOTE=wiedemab;655678] I welded up the factory lead seams with silicon-bronze (same as I did at the roof to quarter seam.
Brandon, Can you explain why you welded with the silicon-bronze on those seams? I think I made a mistake on mine by using my mig.
Bill
My Build Thread;
https://lateral-g.net/forums/showthread.php4?t=40557
Old 03-12-2017, 07:37 AM
wiedemab's Avatar
[QUOTE=HEEP;655705]
I look at it as a way to seal up the joint really well. It's an overlapped and plug welded joint which is what gives it the strength. This is a way to seal up and smooth out the joint while also adding some strength. It should also help with whatever filler you go over the joint with - keep it from flexing as much and showing through the paint (for example when it sits out in the sun and gets hot).
Silicon-Bronze also doesn't have primer/paint adhesion issues.
And to be honest, I'm benchmarking against what the professional shops that I admire are doing. I will also do the seams at the quarter to rocker panel. Not sure if that answers your question.
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 08-07-2017, 06:49 PM
wiedemab's Avatar
Default Some updated pics - -
Another idea I stole from DSE - - had these machines for the dash to house the vents for the heat/AC
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 08-07-2017, 06:53 PM
wiedemab's Avatar
Had to do some more splitting to get the gaps at the cowl right - -got the hood to fender gap looking pretty good.
Welded on new pins for the trim clips...
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 08-20-2017, 08:05 AM
RedrumLs RedrumLs is offline
Default Pops
That's awesome & a blessing! Having pops around to give a helping hand with his knowledge & experience...I wish my dad was still around.. that's probably the exact thing he would be doing... consider yourself fortunate..
Greg
Old 08-20-2017, 11:47 AM
I agree with Greg, enjoy your time in the garage with your Dad. You guys are doing a great job.
