Old 03-12-2017, 10:09 PM
Hell Yeah!
Old 03-15-2017, 11:07 PM
Sonar Chief's Avatar
Thumbs up Some progress!
Hell Yeah!
Thanks for the encouragement ...but it didn't work out like I'd hope
One step forward and two steps backward ... that's how this week has been going. First, the steering column was too long, then the radiator support bolts didn't fit the subframe, and then the gas tank strap rubber u-channel was too narrow.
So I did a little this and that and made some progress. I finished installing the 31 spline Strange axles, which went as engineered, finally, and then installed Millerbuilt end caps ... and filled with gear oil.
Fearing the worst I installed the gas tank and radiator with no surprises.
Oh, the wrap didn't work out as planned mainly cuz of my technique and lack of experience. I sure could have used a second pair of hands too. Lessons learned, don't stretch the vinyl too much cuz it makes wrinkles that are apita to get back out. Had I known the technique of the proper squeegee angle of the dangle I probably could have saved it ... another time I guess. Oh, and if you wet the felt squeegee you won't scratch the vinyl, duh!
So I sacrificed a piece of black vinyl no biggy, I'll have my nephew help me next time, he can hold the vinyl off the panel until I work it down without wrinkles. Didn't take any pics, sorry.
Duh that won't work ... used a 5/16 bolt to attach for now! Frame is too wide!
Pulled the column into the cab the distance of the mounting pads, roughly 2 5/8", the bottom bolts are now top bolts!
That'll work just fine
That's beefy axle fer sure!
Installed as engineered!
Little Loctite on set screws and thread sealant on the cap and it's all set!
That's a cool feature of this Motul gear oil
Gas tank in ....
At least something went right!
Radiator installed w/o a hitch!
So I've been on the phone with Blake and he will pay for shortening the column from the Retro Fit 31.5" down to the 29" where she's at now, that's service, thanks, Blake! The car does steer now! The frame horns being too wide caught Blake off guard, never heard of that happening. Solution ... take some material off the inside slot to get the designed bolts to fit!
Well, that's my week so far, I'll get the front end on this week and hopefully, my rear rims will be in soon so I can get this rolled onto the transport.
Thanks for looking ...
Old 03-16-2017, 07:16 AM
I like thr radiator, I haven't pulled mine out of the box since UPS dropped it off. Can't wait to see the 67 in person!
Old 03-16-2017, 07:43 AM
MillerBuilt's Avatar
MillerBuilt MillerBuilt is offline
Well done Chief, very detailed and looks amazing!
Old 03-16-2017, 08:59 AM
Ok, that hood came out better than I thought!!
Old 03-16-2017, 11:08 AM
Smile
Kevin, she's heading your way here real soon ... and thanks, buddy!
Old 03-16-2017, 11:09 AM
Cool
Thanks Jay for the compliment and working with a nube like me ...
Michael
Old 03-16-2017, 11:24 AM
Smile Some progress!
Thanks Vince, it was a vision and now it's reality ... black wrap will put this hood over the top! Hopefully ...
Persistance ... another word for not giving up! Or I could be a little stubborn ... had to try the wrap again with my new found knowledge, take a look ....
BIG tip ... don't take the wrap off the paper until you need it and NO HEAT until you are ready to set the adhesive!!!
Complex curves cause these wrinkles ... just have to work each one out one at a time!
Working with the lip and reading the wrinkles and applying pressure to relieve the tension ... fingers worked best!
Didn't get them all out but still learning ...
I have to keep on keeping on and get the other side done ...
Old 03-16-2017, 01:54 PM
DT69Cam DT69Cam is offline
Wow, your on your way now !!! Looks great! I love that radiator too. Which brand is it, I couldn't find it in the thread. Thx!
69 Camaro Convertible (LS3/TKO in the works)
Old 03-16-2017, 07:38 PM
Smile
Hey thanks a lot! The radiator is an Entropy LS conversion.
Good garage day ... did some body work on the extension and the header, I'll put some epoxy on these tomorrow, the wrap definitely shows the imperfections just as paint does ...
More experience w the vinyl on the wiper valance, this one was tough, had one Mulligan but overall came out great, take a look ...
Still have to cut the slots out ... this is one tough part to wrap cuz of the vents mainly.
Coat of epoxy and wrap them just like Christmas!
I'm gonna make some waffles now, thanks for looking ....
