  #16
Old 03-19-2017, 03:40 PM
vstol vstol is offline
Well finally back up with the car after building an addition to my home. Went back again to bleed my brakes and nothing in the rear. The Wilwood master brake cylinder was bench bleed and also bleed while on the vehicle. It is not pushing the fluid so I am thinking I need to back out the threads in order for it to completely clear the rear return/orifice in order to get the fluid to the rear. I am getting fluid to the fronts. I plan on calling wildwood tomorrow but keep you ideas coming. Thanks
