Old 03-09-2017, 08:41 AM
Panteracer's Avatar
Panteracer Panteracer is online now
Default Falcon
Craig great work as always
I finally bought a Mig and hoping
I can maybe do somethings close
to what you are fabbing.. in the past
I have just bolted everything.. trying
to get past that
Bob
Old 03-10-2017, 10:38 AM
Try2paz's Avatar
Try2paz Try2paz is offline
are you still using the canister mounted to the PS pump? or have you gone to a remote canister?
1967 Nova
2018 Camaro ZL1 1LE
Old 03-10-2017, 03:36 PM
craig510's Avatar
craig510 craig510 is offline
I am using the integrated reservoir with my KRC pump but I added a vent tube that is tied into my catch can to avoid over pressurizing the system. I have an older Borgesen box and pushed the lower seal out of it after several back to back autox runs. After replacing the seal I decided to add a vent. I still had some issues wth heat at Good Guys and while parallel parking so the cooler went in.
Old 03-10-2017, 10:42 PM
Try2paz's Avatar
Issues as the pump not turning the wheels at low speed? Or overheating? Have you tried any different pump valves? I went up one size in mine to increase flow at low rpn. It helped with parking / tight turns like laguna 7/8.
1967 Nova
2018 Camaro ZL1 1LE
Old 03-12-2017, 10:05 AM
craig510's Avatar
The steering would start to feel notchy. I have not tried the different flow restrictors. I don't want any additional assist, if anything a less would be better. I have thought about getting another Isuzu Rodeo box (the one Borgesen used) and build a stiffer torsion bar for the spool valve and then swap out the internals with my box.
I also got a couple of the GM "J-car" (Barretta) CTO racks that I looked into using but have put on the back burner. At this point I just want to keep the Falcon running and reliable so I can work on my driving while I design the chassis for the Model A.
Old 03-20-2017, 05:58 AM
craig510's Avatar
Well folks. I did it. Won the Spirit of the Event award at this weekends Optima Street Car event and will be heading to SEMA and the Ultimate Street Car Invitational this year. I am very excited and get to check off a bucket list item.
Old 03-20-2017, 07:26 AM
Best photo on the entire internet right now Craig!
That is just pure awesome!
Old 03-20-2017, 08:12 AM
Zoomin Zoomin is offline
Major kudos on that accomplishment!!!
1964 Lemans
1966 Skylark
1969 Camaro
Old 03-20-2017, 11:48 AM
Good for you, Craig! By the way, you're too damned young to have a "bucket list." That's Greg's department . . .
You really have done a nice job of keeping your Falcon "street," as opposed to the four-wheeled motorcycle mine keeps getting closer to. Congrats on the invite!
Old 03-20-2017, 12:08 PM
mad68rs mad68rs is offline
Congrats!
