Old 04-15-2017, 12:18 AM
1badsc 1badsc is offline
Default noise from wilwood brakes
okay guys I installed Wilwood disc brakes that are drilled and slotted and they have a rotational noise when coming to a stop. I did the bedding process got them good and hot like stinky hot let them cool down and the noise is still there the car stops good not great but it stops not sure what the next course of action should be anybody have this issue. I just looked them over today again i notice the outboard pistons looked to be out farther than the inboard ones pads look to be flat against rotor the noise is only when braking rather hard both side of the rotor look great no unusual marks ... Thanks
Old 04-15-2017, 11:17 AM
dontlifttoshift's Avatar
Did you shim to center the calipers?
It's a beautiful day and I'm at the shop if you want to take a ride down, I'll have a listen.
Donny
Old 04-15-2017, 08:55 PM
yes they are shimmed in the middle and i might take ya up on that but most likely one day next week .... thanks David
Old 04-18-2017, 09:07 PM
It was nice meeting you today Donny and the look on your face when ya heard the noise was priceless LOL and i appreciated you taking the time to have a look and listen and giving me a direction to chase and if and when I fix i will let ya know what fixed it ....David
