Old 04-29-2017, 07:32 PM
dhutton dhutton is offline
I have had good success with a Phoenix reverse bleeder I picked up on eBay.
Old 04-30-2017, 03:39 AM
vstol vstol is offline
I was thinking of plugging the MC one at a time and heard a lot about the phoenix V-12 bleeder. Hate to spend $200 or the price of the MC. Maybe chuck Wilwood and go elsewhere.
Old 04-30-2017, 04:35 AM
Plugging one side at a time is a good idea. It doesn't sound like the master is the issue at this point.
Are you running stainless brake lines? They can be a b*tch to seal. Maybe try some conical seals.
Old 04-30-2017, 04:48 AM
Not SS just steel. I do have a wildwood Proportional valve inline to the rear should that be adjusted one way or the other? I am also going to shorten the rod today maybe its not coming back far enough?? also no leaks at all. Thanks
Old 04-30-2017, 06:04 AM
Prop valve should be adjusted for max rear brake. The direction you turn it is counterintuitive so look at the knob carefully. AMHIK...
Old 04-30-2017, 11:14 AM
ok after 1 1/2 hrs of bleeding the brakes the old fashion way the fronts have no air in them at all and work with very little pedal. The rears just when I think they do not have air in them I try to stop the rear wheels to stop at idle and I can stop them but it requires the pedal to the floor. Not good I rebleed them and the same thing. I think I will stop for a while and see if a shop around here has a good bleed tool and can do them. My head is flat from beating it against the wall
Old 04-30-2017, 11:26 AM
Che70velle's Avatar
I've had this problem recently. I was getting the very fine bubbles with my vacuum bleeder. I removed the bleeders from the caliper, and put red wheel bearing grease on the threads of the bleeders liberally. I did this at each corner, and had a perfect pedal in 45 minutes. The ultra fine bubbles were coming from the bleeder screws threads. I went and purchased a new vacuum bleeder during the process, thinking I had an issue with the bleeder. Just about drove me crazy...
Thanks Dad!!
Old 05-01-2017, 03:31 AM
Which Phoenix bleeder did you pick up and what method worked for you? Thanks
Old 05-01-2017, 04:09 AM
This one. I just push fluid from the calipers back to the master.
http://www.ebay.com/itm/Phoenix-Syst...8AAOSwCGVX2GMH
Old 05-01-2017, 05:34 AM
Don was this the vender you bought it from, $134 is a lot cheaper than Jegs at $184.
