Old 05-11-2017, 04:08 AM
Goosesdad's Avatar
Different and aesthetically unrefined.
The outer housing from the E stopp is threaded directly into the block on the right as is the inner cable from the right side park brake.
The inner cable from the E stopp is threaded directly to the block on the left side as is the inner cable from left side park brake. The blocks look like this, I think I had to retap the blocks to match the threads on the Estopp cable and housing.
The outer housings that route to the park brake are mount to a piece of 1" box tubing with a tab on each end. All of the load is contained within that bracket and there is no load at all on the mounts of either the Estopp or the bracket holding the cables.
Why do it this way? When the Estopp is engaged, it tries to pull the inner cable into the outer housing.....pulling the left and right park brake cables closer together. Because it floats, it self equalizes, ensuring that the pulling force is equal between both sides.
Well played sir!! Thanks for sharing.
Have a great day!
John
My Build Thread:
Old 05-11-2017, 05:33 AM
dontlifttoshift's Avatar
dontlifttoshift dontlifttoshift is online now
Thanks, but I stole the concept from Cadillac. That is how they connect the cables on the CTS with the electric parking brake.
Donny
Old 05-19-2017, 06:42 PM
TheJDMan's Avatar
TheJDMan TheJDMan is offline
Donny,
Thanks for sharing this hook up! I was planning to mount my E-Stopp in that same location but was struggling with the cable routing from each wheel. This arrangement makes the routing a cinch. I know how to make this system work now.
Steve Hayes
"Dust Off"
68 Camaro
"Jeremy Clarkson"
