Old 05-14-2017, 10:56 AM
Should be able to bypass the switch to make sure the compressor clutch is working. To replace the switch will require draining the system, it's under pressure.
Old 05-14-2017, 11:36 AM
jblaine86 jblaine86 is offline
I just bypassed the switch and the clutch does work
Old 05-14-2017, 11:42 AM
If there's power to the binary switch but none coming out when commanded and the system is charged correctly it sounds like a bad switch.
Old 05-14-2017, 11:54 AM
That's what I'm starting to think. For my sanity, how can I check to make sure system is charged correctly?
Old 05-14-2017, 02:47 PM
dhutton dhutton is offline
Throw some gauges on it to make sure it is charged. I don't see how they could charge it when the clutch was not engaging but I am not an expert. I know that when I charge them they have to be running....
Old 05-14-2017, 06:48 PM
Ok thanks. I wasn't sure about that either. I will try it tomorrow. Thanks
Old 05-15-2017, 06:49 PM
mitch_04 mitch_04 is offline
dhutton,
Our AC recharging machine will charge without the vehicle running. Charges into the high side and the machine can build some extra pressure to get in the required amount.
Should be simple enough for most shops to drain and swap a switch quickly.
