Old 05-16-2017, 03:13 AM
vstol vstol is offline
Thanks this is my second MC from them. I will give it one more time
Old 05-16-2017, 07:15 PM
JKnight JKnight is offline
Oh, geeze, didn't realize that. Was the first one bad as well? Similar issues?
Old 05-17-2017, 02:53 AM
The first one would not seal at the rear fittings and I went through 3 brake lines and still leaked (wept) at the fitting.
Old 05-28-2017, 03:55 PM
ok bled the heck out this MC and no air so I will reverse bleed the system tomorrow.
Old 05-28-2017, 05:27 PM
carkrazy1987's Avatar
carkrazy1987 carkrazy1987 is offline
im going to buy stock in brake fluid. hopefully reverse bleeding it finally works. may have to go with a nice rusty gm master cylinder if it doesnt work.
1960 Chevy C10 Apache
1969 Chevy Nova
2007 Chevy TBSS
Old 05-28-2017, 06:19 PM
Well, sounds promising. I used a cheapo CPP master and was pleasantly shocked at how quickly the system bled out. Sounds like getting a master with no issues is going to be the key to your system working out.
Old 05-29-2017, 05:39 AM
was it manual or assisted?
Old 05-30-2017, 06:12 AM
I didn't go back to read the whole thread but HOPE that you bench bleed these Masters before installing --- it's a critical step.
Old 05-30-2017, 06:58 AM
I did thanks
Old 06-01-2017, 05:16 PM
No air in the master cylinder and reverse bled all four corners and no air. I have brakes just not sure how much since I only moved the car back and forth in the garage since the steering wheel is not attached. That said the pedal feels soft as my power brakes. I have not driven a manual brake system since 77 but I thought it would certainly take more pressure to stop it. Wilwood said to go with the 15/16ths bore for my car with C4 brakes but I noticed that the C3 manual master cylinders are 1 inch bore.... I might just said @@#$% Wilwood and go to a plan old master cylinder for the C3. This is not rocket science and not my first build but my first with Wilwood. Thanks for your comments
