Old 05-18-2017, 04:20 AM
crestronwizard crestronwizard is offline
Car is awesome. VIR is a short ride for me. Let me know next time you're headed that way, I would like to check it out.
Old 05-21-2017, 03:24 AM
bonecrrusher's Avatar
bonecrrusher bonecrrusher is offline
I see you ran GS/C6Z rotors on your C5/C6 setup.
Was that the only thing needed to get the C7 brakes on your C6 setup?
Do you think Brembo C7 stuff is better then the C6Z PBR's?
2005 LeMans Blue Corvette w/ T56 & Z51 & C6Z06 Brakes, Build Thread: https://lateral-g.net/forums/showthread.php4?t=27408
2005 GMC Sierra 2500HD - LLY - Allison
2014 Chevy SS - LS3 / 4 Doors
Old 05-23-2017, 04:26 AM
Beach Cruiser's Avatar
Beach Cruiser Beach Cruiser is offline
I never actually ran the Z06 rotor with the brembos, but I did mock it up to see if it would work. The only issue I could see without actually using the setup is that the C7 pad hangs just a slight bit over the outside edge of the rotor. This is because the radius it was designed for is different than the radius of the C6 Z06 rotor. but it all fits and bolts together! That's about all I can tell you. I do have some more pictures if you're interested.
No Shop, No Money, No Time.... No problem!
Old 06-01-2017, 07:47 AM
Nola update! finally sat down at my desk long enough to type this up. Like I said before I Hauled the car all the way to NOLA so I could get in three Optima Events this year for the points chase. The drive wasn't fun, and the weekend was exhausting. For the first time in D&E all of my lights and streetcar required stuff worked! Horn, dome light, HVAC, wipers and of course all the lights. Score! The new stereo in the car helped with D&E too, and I recorded my highest D&E score to date. Stereo? yep, I put in a thumping mostor stereo thanks to Soundwave Customs here in Va Beach.
Back to NOLA, the veryfirst autocross run my entire exhausts dropped off the headers halfway through! yikes! I'm just glad my wideband O2 wires kept it from coming all the way off and I was able to salvage it. It took about an hour to get the car up on stands and replace the exhaust, so I lost quite a few autox runs. Once back, something didn't sound right and there was a lot of clunking going on in the rear end, I ran a total of 4 runs and during the lunch break I put it back up in the air to check things out. Well, the crossmember that holds the Pinion mount (IRS remember) was broken in two! Its a 3" piece of heavy pipe! broken. No more autox for me that day. Patched it up best we could for the road rally, and I was extra extra gentle on it for the rally portion. Once back to the track we tore into it to remove the crossmember and re weld it back together for Sundays action. Good thing we had a keg because that attracted a lot help! We managed to get it out and one of the other teams stepped up to help us weld it with their portable set. Got it back into the car and finished the keg about 1am sunday!
On Sunday I made sure I got at least one speed stop run in before I hit the open track laps just incase I had any issues in either. Turns out the parking lot welding and extra bracing held up just fine all day on Sunday!
I gave it all she had on the road course and even sprayed a whole bottle of NOS through it, but I just couldn't make up enough ground to take the GTV win home. I was close, and only a few points out, but it's not a win. Still 2nd in GTV is my highest finish yet! and I got to grab some of Falken tire's contingency money! win win!
Old 06-01-2017, 10:38 AM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
After every event it's important to debrief and go over the lessons learned. In this case....Always have beer on hand. Preferably cold.
Curtis
Old 06-01-2017, 07:17 PM
HereHere!! BEER!
Old 06-08-2017, 04:24 AM
Curtis, I just got the invite this weekend for SEMA! how many kegs do I need to stuff in the car for transport? can you keep them cold for me until I get there?
