Old 06-01-2017, 11:28 PM
manny z manny z is offline
Default updates with pictures
Alright first and foremost the whole idea with the dodge Dakota sway bar, is going to have to get shelved. Seems that the QA1 lower arms are a little different then the stockers. So it looks like I am going to go back to my idea of using the Speedway torsion bar style bar.
I finished up the tie rod situation. Now that I have them just where I want them, I am sure the bump steer will be just where I want it.
Also you will see the picture of the frame connectors. You can see how I tied them to the front frame rails, and the cross member for the torsion bars.
Don't have a picture of but, did work on my oiling system. I am running a Keith Black swinging pick up oil system. I misplaced one of the fittings so, I decided to get all new hardware for the feed side of it. All black AN fittings, and black braided line.
In one of the pictures you will see that the oil pan is flush with the K member. I made this pan out of a rear sump big block pan. Used a Moroso wide pan kit, and baffle kit.
I wanted to make sure that this engine will not starve for oil, EVER.. haha.
One picture of the rear sump I installed on the new gas tank. I am going to be running a feed and return line, both -10.
Mounted the fuel pump, on the rear rail, with the filter, up to a boost ref regulator.
Next a partial picture of the exh. The headers will be 2" primary tubes, as equal as they could of been. The collectors I decided to use are 4"x4" turbo waist gate square flanges, 7/16" thick. These are never going to warp from the heat. I am going to use 2 flex tubes right after the collectors, down to 3" to 3 1/2" oval tubes, into the X pipe, to a SPINTECH MUFFLER, on its way, to a boom tube coming out of the drivers side in front of the rear tire.
And one night while watching TV, I decided to take a Leather steering wheel cover, and some 1/8" thick dense foam. Also used white stitching for it.
Was thinking about aftermarket but, I could not find one that fitted to look I was looking for.
