Old 06-23-2017, 07:44 AM
572Camaro's Avatar
This project is killer awesome!
PLEASE keep posting!
I too would go whipple
Old 06-23-2017, 07:57 AM
black2002ls black2002ls is offline
Thanks. It's been going off and on for about a decade. I'm hoping with the new availability of parts, I can keep the momentum going.
The cool thing about those 3D printed parts, the guy that created the LS3 has a full set of internals too. It would make a sweet little diorama. The down side is the cost. The fine detail material gets to be super expensive.
1/12th scale 1969 Sunset Orange Metallic Camaro Pro Touring Style>>
Progress Thread
Artwork Page
Old 06-23-2017, 08:45 AM
syborg tt's Avatar
Just curious what would they cost ??
marty-mj
Old 06-23-2017, 09:54 AM
1/8th scale, with the way he has everything listed in his store, about $200 for the parts. This is with the majority of the prints being in material that leaves a lot of texture. This is ok for the block if you are going for a factory cast look. If you want a machined, LSx look, it would need to be printed in the high def material which drastically increases the price. The other parts can be smoothed, though it would take quite a bit of work.
I know he prints 1/4 scale parts, though he prints those in house and I don't have a price on that. I could get a price if you were interested in a scale LSx diorama for a desk piece or something.
Edit: That total cost could probably be reduced if I had him put it into the store as a "kit" with all of the pieces in one file to print, that could reduce the cost.
Progress Thread
Artwork Page
Old 06-23-2017, 10:19 AM
A few things to try and show the process, and trials this thing has been through.
The over sized wheels I mentioned were going to be SWEET, had they turned out correctly. The centers had the look I was after, though after the sleeves got machined, they turned out to be 23" in scale I think, and once I mocked them up, they were entirely too large.
The process:
I drew up the wheel centers, printed some test pieces, and like the look, though I felt they needed to be a bit bigger, the original spokes were too narrow and I felt the wheel was a tad too small. Upon re-design I printed new pieces and then ended up stalling because I couldn't find anyone to machine the wheel sleeves. I finally came across a group of modellers who had a Facebook group dedicated to big scale modelling (1/16th-1/8th). It was there I got hooked up with a guy who could do what I was looking for. So, I set out to get the wheels finished, one of the major hang ups of this project.
This is how big they turned out:
You can also see here that the guy machined the wheel sleeves for the center to be rear mount, I was looking for front mount, to replicate a 3 piece wheel. They were also machined with a "stepped" lip and I was looking for a smooth transition from the lip to the center. So, we talked it over and I sent them back to have him separate the sleeve and the mounting ring so that I could adjust the centers to the depth and mounting orientation that suited the build.
Here is what I got back:
Unfortunately when doing that, I was left with sleeves that did not have a smooth inner diameter, and mounting rings that did not fit snugly inside of the centers. Leaving me with parts that were all but useless. In the midst of all of that I thought about the lack of tires for the build, and once tires were on it, they wheel/tire combo was going to be ENTIRELY too large and look like a Donk.
Progress Thread
Artwork Page
Old 06-23-2017, 10:28 AM
Fast forward a few months and I got bored and started digging thought my box of parts. I found some tire casts that a guy in California sent me to mess around with, my original prototype wheels, and found that everything fit together almost perfectly:
They also looked right at home on the rear of the Camaro (notice the body was still black with hockey stripes at this point)
So, that set the wheels in motion to start trying to source parts, and reinvigorated the build.
It was at this point I came across some old reference photos as well as photos of the body when it was painted Sunset Orange Metallic in the beginning. This set me on a course to strip the body, which took about a month of soaking in various chemicals, and prepping to re-paint it SOM. This time around I used a mail order auto refinishing site and picked up some SOM in a spray can and got the finish I was after, minus the tiger stripes.
So, where does this leave me you may wonder?
The wheels need some work. The centers are a little loose in the sleeves, not so loose that they aren't usable, but loose enough to make getting them mated together square and looking right could be an issue. Ideally, they need drawn with a "stop" for the wheel center at the proper depth for the offset I'm looking for, problem there is, I don't know what offset I'm after! These aren't necessary, but would definitely help. In addition to that, I would like the spokes on the wheels just a bit "beefier" as the look anemic as they sit. The brakes that I designed need to be scaled down, as they were designed to fit the larger wheels, and now that I'm going with the smaller ones, they will not clear. Then, once all of the adjustments are made, I need to "group the parts" in a Solid Works file and upload them to be printed.
Anyone familiar with solid works? lol
Progress Thread
Artwork Page
Old 06-26-2017, 06:05 AM
PASD U PASD U is offline
Glad to see this is still going. I've debated building one myself but I would get a lot more frustrated. I'm way too picky wheels/tires having the right look. Closest thing I found I could use was kitbashing the detail kits for Pocher Ferrari F40's or Lambo Aventador. There is/was someone even making aftermarket tires for them
