Old 06-25-2017, 09:54 PM
SlowProgress's Avatar
Man you are really making progress now. Looking at all the little details is both exciting and terrifying, reminds me how much I have to do still !
Old 06-26-2017, 09:14 AM
1in1969 1in1969 is offline
If you will put a zip tie on the braided line where you want to cut and then use a cut off wheel to cut into the zip tie and line at the same time, the zip tie will melt and keep the braided together, peeling off the melted part after cool down. It does take a little practice though.
Shawn
Old 06-26-2017, 01:30 PM
TomM's Avatar
TomM TomM is offline
I use one of these...
http://www.jegs.com/i/Vintage-Air/960/420004/10002/-1
And this....works perfect...
http://www.jegs.com/i/KOUL-tools/581/468/10002/-1
T,
Old 06-27-2017, 06:19 PM
Thanks guys
I've been in contact with a guy to do some aluminum tubing welds for me. He was supposed to call Monday ,so I text him and still nothing. Sounds like time to look else where.
Tomorrow we're going to try to epoxy and tap the power steering reservoir for the returns from the Hydroboost and steering box. I hope something hold on it epoxy wise.
Old 07-15-2017, 11:20 AM
A lot of small progress done since my last post we installed a couple of fittings on the power steering reservoir and I plumbed it in and mounted on the fender well. I used XRP hose and AN fittings made for power steering pressure.
After talking to rep from Injector Dynamics who recommended a 10 micron filter, I picked up a Fuelabs ceramic filter good for all fuels. Then we marked up some hoses that will need to be sent out to be crimped. This pic only shows where it will be mounted, it still needs to be attached to the firewall. I.D. wanted it as close to the injectors as I could get it.
It's not as close as it seems to the header plus it has a heat protection cover on it. The bottom of the filter will be moved over to mount it plumb.
Old 07-15-2017, 12:32 PM
We're into the wiring now Not my favorite.... Like Greg W. says one thing at a time!
I had the injector harness covered the same as the rest of the wires but it was too stiff to go where I needed it, so it went back to the way the factory had it.
And my latest part from GM $28
GM tucking it to to you one part at a time!
Old 07-16-2017, 05:23 AM
kwhizz's Avatar
kwhizz kwhizz is online now
$15 thru gmpartsdirect.com Just Say'in ........
Old 07-17-2017, 05:09 PM
cryptonomad cryptonomad is offline
[QUOTE=waynieZ;662278]We're into the wiring now Not my favorite.... Like Greg W. says one thing at a time!
Looking good Wayne! A lot of quality work!
Old 07-28-2017, 04:43 PM
rixtrix1's Avatar
rixtrix1 rixtrix1 is offline
Default Moving ahead
Wow, Wayne, before long you're going to walk out into the garage and say,
" Well, time to strip this thing down for paint!"
Ric
Old 07-29-2017, 05:16 AM
DT69Cam DT69Cam is offline
Wayne, what is the Finch vent for? The gas tank ??
69 Camaro Convertible (LS3/TKO in the works)
