Old 07-03-2017, 10:59 AM
cpd004's Avatar
cpd004 cpd004 is offline
Not sure if it'd be quicker here, but try this:
http://www.mouser.com/ProductDetail/...FB06epEg%3D%3D
1971 Firebird
2017 SS
Old 07-03-2017, 02:23 PM
randy randy is offline
I made a hole behind the motor
Old 07-03-2017, 05:34 PM
jwcarguy jwcarguy is offline
Banned
Agreed with Randy
Behind engine, but alot of care and attention to measuring, engine placement and rear vac port of intake manifold
tape off firewall and lay it all out, then verify and interior conflicts (ie ac/ heater box, ducting, etc, etc) prior to punching any hole in it
Old 07-03-2017, 05:30 PM
Banned
That has to be installed on the harness during the building of harness, unless you "cut/ split them" length wise, but they dont seat or seal well sometimes when you do that
Old 07-03-2017, 06:45 PM
cpd004's Avatar
Correct. They have to be split and will seal fine. This is the same grommet that Speartech sells. I posted the mouser link and Delphi part number to give the OP an alternative way of getting it quicker.
1971 Firebird
2017 SS
Old 07-03-2017, 08:31 PM
Split it and it will seal fine.
Old 07-04-2017, 11:45 AM
Banned
I have used the grommets from Seals-it with great luck ( use in the offroad world that I deal with also)
http://sealsit.com/product-category/...-grommet-seal/
just a example, they are available in numerous sizes (I.D. & O.D.)
