Old 07-21-2017, 07:44 AM
Josh@Ridetech's Avatar
Josh@Ridetech Josh@Ridetech is offline
Going to be a wicked car when it's done! Keep it up man, let me know if I can help out at all.
Old 07-22-2017, 05:58 PM
kmart401 kmart401 is offline
What gearbox are you running? Thats one wicked ride!! Can't wait to see more pics of this one!
Old 07-26-2017, 11:39 AM
Nativefx Nativefx is offline
Running a close ratio T-56 Magnum mated to a 9" floater rear end with 3.89 gears.
Old 07-26-2017, 02:19 PM
jlwdvm jlwdvm is offline
We have similar taste...check this out: http://www.pro-touring.com/threads/1...rack-car-build
I have DSE subframe connectors and a Alston 8-point cage with solid body mounts. I have about 150 miles on the car so far. Shaking it down before paint...69 Trans Am scheme. Its extremely loud and fast. I think I'm just gonna fab up some aluminum door panels and a rear seat delete. Not gonna put windows in it to save weight and hassel. It will never see rain anyway!
Old 07-26-2017, 09:29 PM
It's been awhile since I came across your build thread! I'll have to check out your updates. Maybe it will help on a few other things I'm thinking about.
Old 08-04-2017, 11:06 PM
David Pozzi's Avatar
The front of the subframe needs support more than the rear subframe does. The stock sub is terrible in torsion ahead of the firewall. The front sheet metal contributes to half the front torsional rigidity. jlwdvm, - If you do a roll bar or cage, I highly recommend adding a diagonal brace to the main hoop. SCCA requires it, and it's a main component of any good roll bar. It can be removable by adding some double shear brackets.
http://www.PozziRacing.com
Old 08-05-2017, 09:55 AM
Originally Posted by David Pozzi View Post
The front sub needs support more than the rear does. The stock sub is terrible in torsion. The front sheet metal contributes to half the front torsional rigidity. jlwdvm, - If you do a roll bar or cage, always add a diagonal brace to the main hoop. SCCA requires it, and it's a main component of any good roll bar.
Thanks David. Any advise on how I can better support the front sub? Would something like the Alston subframe connector cross braces help with this? I'm open to other ideas as I really don't think I want to put a cage in it. thanks
Old 08-08-2017, 06:27 AM
Do you mean: from the point above my head where the rear brace meets the main hoop to where the passenger side brace meets the trunk floor? I have thought about it.
