Old 08-16-2017, 03:54 AM
tubbed69's Avatar
tubbed69 tubbed69 is offline
Originally Posted by DT69Cam View Post
That is the clutch I had and just found out from McLeod that I can NOT use this clutch with their TO bearing. The McLeod TO bearing will NOT function properly with the LS7 clutch.
I always used the to bearing from Kreisler engineering.
