Old 08-21-2017, 12:53 PM
DT69Cam DT69Cam is offline
Originally Posted by JKnight View Post
I guess we should start with the simple stuff. You using a clutch alignment tool? Plastic or metal? Mechanical linkage? I had to depress the clutch a bit to get the input shaft to seat properly.
Hydraulic TO bearing, Ram clutch. Plastic alignment tool.
69 Camaro Convertible (LS3/TKO in the works)
