Old 08-21-2017, 08:40 PM
V8TV's Avatar
V8TV V8TV is offline
Door reinforcement bars keep the body from twisting on the rotisserie.
Bolted to the spinner and ready to go!
The suspension parts and core support will be media blasted and painted to look new again.
The Heidt’s subframe is essentially new, having never been painted or driven. However, it’s not “calendar” new. We’ll blast and paint it with Axalta epoxy and Imron as well.
Kevin Oeste
V8 Speed and Resto Shop
V8TV
Muscle Car Of The Week
V8 Radio Podcast
All about us:
https://www.v8speedshop.com
Old 08-22-2017, 04:39 AM
It looks good Kevin, nice work.
Old 08-22-2017, 05:15 AM
gofastwclass gofastwclass is offline
Excellent.
I build my own junk...
Old 08-22-2017, 03:39 PM
V8TV's Avatar
Originally Posted by gofastwclass View Post
Excellent.
Thanks guys!
Kevin Oeste
V8TV
V8 Radio Podcast
All about us:
Old 08-31-2017, 01:37 PM
V8TV's Avatar
The bottom of the car is easier to access with the body of the Camaro on the rotisserie, so final grinding and detail work was done in this position. The transmission tunnel and floor repairs were dressed from the bottom.
We took the opportunity to strengthen the frame rails where the Heidt’s rear 4-link bars connect to prevent the rails from being crushed by the mounting bolts. This was done by making a set of plates shaped to conform to the rails, then drilling mount holes and welding them in place with the HTP MIG 200 welder.
Kevin Oeste
V8TV
V8 Radio Podcast
All about us:
Old 08-31-2017, 01:40 PM
V8TV's Avatar
The bright spots on the floor supports indicate where minor rust repairs were made.
In the paint shop, numerous parts were prepared and painted. The process can include media blasting or chemical cleaning, a hand sanding or Scotchbrite rub, then various wax & grease removers to clean the parts before they are masked and hung in the paint booth. FBS Distributors sprayers are helpful to rinse parts down, and tape labels an tags are often used to ID the parts. It’s a long process, but the results deliver great coverage and adhesion.
The Heidt’s subframe was meticulously sanded, cleaned, and hung in the booth for Axalta epoxy and satin black Imron paint.
The completed subframe looks pretty sharp!
Kevin Oeste
V8TV
V8 Radio Podcast
All about us:
Old 08-31-2017, 01:43 PM
V8TV's Avatar
The next phase was to prep the bottom of the body shell for paint. Again, the entire tub was sanded and cleaned, then masked and cleaned with wax & grease remover before receiving Axalta epoxy primer. If this was to be a “show” car, the bottom side would have been media blasted, but COMP wanted a driver and did not put a high priority on underside detail.
The inside of the tub was cleaned and prepped as well.
Kevin Oeste
V8TV
V8 Radio Podcast
All about us:
