Old 08-27-2017, 05:59 PM
clill's Avatar
clill clill is offline
I also am concerned about using copper tubing for brake lines. Copper generally does not hold up to vibration very well. Maybe I am reading what you wrote wrong ?
Old 08-27-2017, 06:13 PM
rickpaw rickpaw is offline
It's probably NiCopp. Copper/nickel alloy I believe. Not pure copper. It's supposed to flare much easier than stainless, yet resist corrosion better than regular steel.
Tu Ho
Old 08-27-2017, 06:42 PM
jlwdvm jlwdvm is offline
Yes...NiCopper....the good stuff from England. Maybe I took Ron's advice a little too literally!
Old 08-27-2017, 06:52 PM
Musclerodz's Avatar
If you having to pick the pedal up, make sure you do not have an interference at the firewall. Also make sure you have the calipers shimmed within spec. If you have a pad riding on the rotor, it could build enough heat to push on the rotor if it doesn't have proper clearance.
Mike Redpath
Musclerodz & Customz
facebook page
Old 08-27-2017, 07:34 PM
I figured I had to do the toe thing to get the brake lights to turn off because of a combination of the brake light switch not properly adjust and the brake pedal rod not properly adjust for length. Today's problem didn't show up until I lengthened the master cylinder push rod end...to preload the master.
Old 08-27-2017, 08:56 PM
blitzer454 blitzer454 is offline
Preloading the master cylinder sounds like a bad idea to me. The piston in the master cylinder needs to be fully uncompressed when your foot is off the brake otherwise the port to the reservoir will be blocked off, and believe me it doesn't take much movement of the piston to block off that port. You also won't be able to bleed the brakes when that port is blocked by the piston. The booster to master cylinder rod needs to be adjusted such that there is a small gap between the rod and the piston of the master cylinder. Then adjust the rod length of the other side of the booster to fix the brake light problem.
Also make sure your parking brake is working. It could be that the pistons in the rear caliper is having to travel too far because the parking brake has not been adjusted.
Old 08-27-2017, 09:16 PM
Musclerodz's Avatar
you don't preload the master. it has to have play so there is no pressure on the brake system when your not using it or the end result is your brakes trying to lock up.
Mike Redpath
facebook page
Old 08-28-2017, 05:41 AM
Manual system....no booster.
