Old 09-03-2017, 03:55 PM
andrewb70's Avatar
Does anyone know anything about the PWM configuration on the new LT1 and LT4 GMPP kits that use the e92 ECU?
Presumably there is a PWM output, but maybe GMPP did away with it on the retrofit kits (as they did on the e67 kits, as John Parsons experienced). I also know that the new generation of fans the WPM controller is built into the fans, so no intermediate controller (like the C6) is needed.
Andrew
Old 09-04-2017, 05:04 PM
PTAddict PTAddict is offline
Andrew
I have an LT4 and the GMPP controller kit, and a late model CTS-V cooling fan, but we're a month or two from finishing wiring and getting things running. I am hoping that I can reprogram the e92 with HPTuners to do PWM control as it does in a CTS-V - we'll see. Why GM would block PWM control in the crate motor ECUs is beyond me ...
Latest car: https://lateral-g.net/members/borduin/
EFI Tuner for: http://www.modernclassicsauto.com
Old 09-04-2017, 05:31 PM
andrewb70's Avatar
Thanks for chiming in! Please keep this thread updated. I know from another LT4 build that the stock GMPP fan configuration is discrete fan control, with a Hi and Low fan setting. PWM would be way better, especially if you're using the new CTSV 800watt fan.
Have you found a source for the Yazaki connector and terminals for the fan?
Andrew
Old 09-07-2017, 11:03 AM
ProServ ProServ is offline
Default Fan connectors
I haven't seen the CTS-V fan. Does it use the same connectors as the C7 Corvette and the aftermarket released Spal DC brushless fans? If so I have those connectors in stock as kits with terminals seals etc.
Here is what I have:
Multiple terminals and seals are provided to account for different gauge wire applications.
Jason Haines
Product & Service Solutions LLC
[email protected]
www.proservsolutions.com
Andrew
Old 09-09-2017, 09:40 AM
Andrew
I got the connector from Summit:
https://www.summitracing.com/parts/SPU-IXSBLYAZPT
Edit: the above part number is complete connector, terminals, and harness.
The GMPP controller is indeed set up for discrete control as it comes, I'm just assuming I can change that like on most GM ECU.
Old 09-11-2017, 02:25 PM
andrewb70's Avatar
Scott,
Thanks for the info!!!
I am eager to see if you can change the tune in the e92 for PWM fan control.
Andrew
Old 09-11-2017, 03:56 PM
blake-b blake-b is offline
Has the E38 been figured out for PWM fan control?
I have a 2010 Camaro and a radiator coming with twin Spal brushless fans. I called Spal and they wouldn't tell me anything because of an NDA with GM as they are an OEM supplier. I called the place building the radiator and was told the same thing but they'd see what, if anything, they could find out because they have not installed in a 2010 Camaro.
Dave Steck (DSX Tuning) is a friend of mine and I contacted him about it. He said the Corvette and Camaro E38 OS are the same but have differing CANbus communication. He said he sees no reason I can't control the fans with PWM because the OS has PWM Electric as a choice. That is a screenshot of my actual tune showing it.
Unless I missed something in this thread (quite possible) I haven't seen anyone successfully running PWM in a 5th Gen Camaro and an E38 ECM.
It would be nice to be able to just drop the new fans in, connect the wires and go.
ETA: I don't know which fans I'm getting as the place (wizard cooling) is going to use the biggest ones that will fit. 14" diameter and 3. 25" thickness was mentioned. I am not aware of any other aftermarket 5th Gen radiator having 14" fans though.
Old 01-26-2018, 07:16 PM
vannatta20 vannatta20 is offline
A 5th gen camaro e38 os will not support pwm. But a truck e38 os will. Also the e92 silverado controller will only support pwm at 100hertz. No discrete on the new stuff factory os.. The gmpp e92 controller will support discrete only. Its all super confusing and testing is the only way to know for sure. Lot of misinformation out there. I use an oscilloscope at work to see the signals. To get ac control the computer needs to get a serial on request from the bcm. We have a module the sends that signal along with tap shift commands for gen iv and gen v. This control the fan based on ac pressure as well. Works perfectly.
Old 01-23-2019, 01:55 PM
Coursey Coursey is offline
Default 2015 Camaro L99 6l80 e38 will PWM work on spal brushless 12" twin fans?
Was you able to get this working?
I am installing the following setup in my 1976 Blazer.
L99 DOD delete with 6l80e from a 2015 Camaro
I have 2-12" Spal Brush-less fans part numbers 30107087 VA89- ABL320P/N-94A
I also have vintage air.
Looking at the wiring diagram for the brush-less fans it appears that they do not run throw a relay. It says to just install a 40 amp Maxi Fuse.
I am wanting to hook these up to run PWM so that they are variable speed like a new car. I would like the fans to be controlled by my e38 ecm. I am also installed a pressure transducer on the ac line.
With the 2 fans do i need 2 controllers?
The Following User Says Thank You to Coursey For This Useful Post:
yanyere (01-25-2019)
Old 01-09-2024, 12:05 PM
SCP Auto SCP Auto is offline
Andrew
Hello did you find a way to use GMPP E92 to run the cooling fans with PWM
