Old 09-18-2017, 01:38 PM
Z06vette's Avatar
Z06vette Z06vette is offline
If you are running all the newer holly lsx swap parts, you shouldn't have to raise the tunnel. I just dropped that same setup in a 69 (T56, not a magnum). In reading their paperwork it should work without cutting the tunnel with the magnum as well.
69 RS LS3/T56
68 firebird vert LS1/4L60E
67 RS LS2/T56
Old 09-18-2017, 07:50 PM
69Camaro's Avatar
69Camaro 69Camaro is offline
I will test fit the trans before I cut, but the paperwork I have says with the Magnum you must cut the tunnel. My QuickTime bellhousing just arrived so I will test fit once I finish the subframe connectors.
I hope you're right and I don't have to cut the tunnel.
1969 Camaro
Kore3 Z06 brakes
Hydratech hydroboost
Wilwood master
Ridetech stage 2 with truturn
Forgeline GA3 18x9.5/18x12.0
BFGoodrich Rivals 275/35 & 335/30
Magnum T56
Lots of AMD sheet metal
Sprinkled with DSE parts
Ididit Steering column
GM 376/525hp crate
Moser 12 bolt, tru-trac, 3.73:1
Speedhut Guages
Vintage Air
Corbeau LG1’s
Digi-tails
Ringbrothers
Harwood cowl
Old 09-19-2017, 09:40 AM
ADY's Avatar
ADY ADY is offline
If you end up cutting your tunnel like I had to in my '68, Speedtech makes a pre-fab tunnel cover that I attached with 3M body panel adhesive.
http://www.speedtechperformance.com/...rod/prd264.htm
-Adam
1968 Camaro SS
Old 09-19-2017, 11:16 AM
Z06vette's Avatar
This tunnel was a much batter match & fit than the speedtech tunnel. I ended up returning the speedtech. It just doesnt have the extra room in the right places. Now I was using running a DSE frame, but the space needed to raise the trans should be generally the same.
https://www.cachassisworks.com/p-278...56-magnum.aspx
69 RS LS3/T56
67 RS LS2/T56
Old 09-19-2017, 07:54 PM
69Camaro's Avatar
Thanks for the feedback, I hope to get the transmission fitted next weekend. I will check out the chassisworks piece.
1969 Camaro
Kore3 Z06 brakes
Wilwood master
Magnum T56
GM 376/525hp crate
Speedhut Guages
Vintage Air
Corbeau LG1’s
Digi-tails
Ringbrothers
Harwood cowl
Old 09-22-2017, 03:49 PM
Chevy Kid Chevy Kid is offline
I have a ls1/magnum with all of the Holley gear on my 67. Slight trimming of the shifter hole, but no other tunnel mods.
Tim
Old 10-07-2017, 12:57 AM
Nativefx Nativefx is offline
I got my whole trans/clutch/hydraulic setup from Silver Sport Transmissions. It was a great experience and I had a number of questions before and after I purchased. I upgraded my clutch to the McLeod RST as well. This is going to be mated to my Thompson Motorsports 550hp forged LS3.
