Old 09-20-2017, 04:12 PM
redzo6 redzo6 is offline
Thanks friends, Don I will order a couple of those connectors. Thanks for the heads up. I am hoping after a different setup that I don't have a stalling problem.
Also, Frank from entropy suggested that I might need a radiator hose sleeve for the temperature sensor on the entrophy system, Is there anybody else or any better idea for the temperature sensor?
Old 09-20-2017, 05:07 PM
dhutton dhutton is offline
You can mount the sensor in the rear of the passenger head.
You can use one of these adaptors but I can't remember which one
http://www.ebay.com/itm/Water-Temp-S...pRP8Mn&vxp=mtr
Entropy can tell you if you need 1/2 or 1/4 NPT for their sensor.
Old 09-21-2017, 05:14 AM
130fe 130fe is offline
Post
The entropy sender is 3/8 npt, would need a different adapter than the ones Don suggested. I actually contemplated trying out a stock LS sender in the head. All of those senders -water temp (from what I understand) just send out a resistance "signal". My plan was to compare the readings that the entropy sender and LS sender and see if I could enterpolate them to use the LS only sender. I believe the plug for both is the same. Just a thought.
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 09-21-2017, 06:16 AM
Interesting. I used an adaptor like the ones I listed. I will see if I can find a link.
Old 09-21-2017, 06:19 AM
Thanks,
Here it is:
http://www.ebay.com/itm/LS-Engine-Sw...pRP8Mn&vxp=mtr
Old 09-21-2017, 11:16 AM
Smile
Yeah Don, that last link was probably the one you used. I always wondered when using one of those adapters if the larger sensor body would get enough "exposure" to activate the sender trigger. Good to know they work. I had also looked into using one of those radiator hose "couplers". Most of them only had 1/4 npt threaded bung in them. You would have to drill and tap the thing for the 3/8 npt threads. In the end, I ended up getting an Entropy radiator. Nice piece, with powerful fans and it already have the correct 3/8 and 1/4 npt bungs in the unit.
Chris
1968 Camaro SS
LS3/T56
Old 09-21-2017, 11:34 AM
Hi Chris. I have used a few Entropy radiators with good results. For my wife's car I got a deal on a Dewitt radiator and had to place the sender in the head. Seems to work fine.
