Old 09-21-2017, 05:14 AM
130fe 130fe is offline
Post
The entropy sender is 3/8 npt, would need a different adapter than the ones Don suggested. I actually contemplated trying out a stock LS sender in the head. All of those senders -water temp (from what I understand) just send out a resistance "signal". My plan was to compare the readings that the entropy sender and LS sender and see if I could enterpolate them to use the LS only sender. I believe the plug for both is the same. Just a thought.
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 09-21-2017, 06:16 AM
dhutton dhutton is offline
Interesting. I used an adaptor like the ones I listed. I will see if I can find a link.
Old 09-21-2017, 06:19 AM
Thanks,
Here it is:
http://www.ebay.com/itm/LS-Engine-Sw...pRP8Mn&vxp=mtr
Old 09-21-2017, 11:16 AM
Smile
Yeah Don, that last link was probably the one you used. I always wondered when using one of those adapters if the larger sensor body would get enough "exposure" to activate the sender trigger. Good to know they work. I had also looked into using one of those radiator hose "couplers". Most of them only had 1/4 npt threaded bung in them. You would have to drill and tap the thing for the 3/8 npt threads. In the end, I ended up getting an Entropy radiator. Nice piece, with powerful fans and it already have the correct 3/8 and 1/4 npt bungs in the unit.
Chris
1968 Camaro SS
LS3/T56
Old 09-21-2017, 11:34 AM
Hi Chris. I have used a few Entropy radiators with good results. For my wife's car I got a deal on a Dewitt radiator and had to place the sender in the head. Seems to work fine.
Old 10-26-2017, 11:16 AM
redzo6 redzo6 is offline
Hello all, Well I have everything hooked up and triple checked. I am having a problem with the trinary switch not grounding out when the pressure reaches 220 psi turning the fans on.
The green entrophy wire which is attached to the blue wire on the trinary is putting out 4.5 volts (hooked or unhooked from trinary), the other blue wire on the trinary is grounded to the frame. The black and green trinary wires are hooked to compressor clutch and the other is hooked to a/c controls on the dash when power turns on.
The fans come on fine when the car reaches temperature but not when a/c pressure.
Both blue wires on trinary unhooked do not have continuity but when hooked up to entrophy wires, I get continuity.
I am so lost. cant figure this out. Thanks in advanced
Old 03-28-2018, 07:35 AM
cpd004's Avatar
cpd004 cpd004 is offline
Were you able to resolve this? I'm considering that fan controller, and just want to make sure it will work with a similar swap I have going on.
1971 Firebird
2017 SS
