Old 10-02-2017, 05:29 AM
Stielow's Avatar
Stielow Stielow is offline
Sorry Greg I revised my original post with more detail. See above.
Mark
I use this to just Bleed my brakes. An adaptor to the C6 Corvette brake reservoir and a cheap pressure regulator to hold 50 psi to the system.
Mark
Stielow Engineering
Old 10-02-2017, 05:49 AM
Thank you for the update Mark!!!
Old 10-02-2017, 09:53 AM
NAPA 68 NAPA 68 is offline
Great info!
Old 10-02-2017, 10:17 AM
71RS/SS396's Avatar
Sooo....When will the "Stielow Bleeder" be available for purchase?
Old 10-06-2017, 10:36 AM
CarlC CarlC is offline
Mark, where did you find the reservoir cap?
http:www.vaporworx.com
Old 10-06-2017, 11:59 AM
dontlifttoshift's Avatar
https://www.amazon.com/Motive-Produc.../dp/B00YS8JW54
Donny
Old 10-06-2017, 01:27 PM
Boss 5.0's Avatar
Boss 5.0 Boss 5.0 is offline
I use one of these for filling cooling systems....
https://www.matcotools.com/catalog/p...TEM-AIR-PURGE/
From what you are describing and show it is almost exactly as this works for cooling. It draws vacuum down and makes sure there are no leaks, then with the hose dropped into the coolant you open the valve and it forces it into the entire system. I haven't had to burp a system since 1996 when I bought this.
A system like this for brake fluid would be incredible!!!
Copper Hill Rod & Custom
1955 Chevy BelAir
1951 Chevy 3100
1987 Chevy R10
Glenn
Old 10-07-2017, 07:11 AM
Stielow's Avatar
This one works better
Power Probe BA04 Brake Bleeder Adapter https://www.amazon.com/dp/B0037668CI..._xYqT8ERFtwZLL
Seals a lot tighter.
Mark
Old 10-17-2017, 05:12 PM
67rsssls's Avatar
67rsssls 67rsssls is offline
Hey Mark,
Does the factory use something similar to fill the hydraulic clutch system?
Thanks,
Steve
Steve
Old 10-18-2017, 12:25 PM
preston preston is offline
Looks good and could uncover small leaks, but I've never had an issue getting a rock hard brake pedal just using one of those cheap pressure bleeders. I felt like I found God the first time I used one instead of pumping the pedal. But I don't have an ABS module either.
