Old 10-17-2017, 02:45 AM
vstol vstol is offline
Originally Posted by Hydratech View Post
Hi Kevin - Sorry about that... Monday's are either very quiet (with Jim playing card games on the PC bored stiff) *OR* crazy on fire. Today happened to be the crazy on fire Monday - Jim was totally overwhelmed = sorry that you couldn't get through appropriately. I saw your e-mail that you sent in, and forwarded it to Jim with instructions to give you a jingle. Is there a best time for you to take a call? Please note that Jim is only in the office from 10am to 3pm CST (live local time clock on our contact us web page).
Great I will call again as I am in VA. Busy is good
Old 10-17-2017, 02:47 PM
All good info.....
I have a couple (3 and building a 4th) race cars.... ran Thunderhill this weekend - Wilwood 1" MANUAL master cylinder... Wilwood 6 piston front - 4 piston rears.....
I'm running down into turn one at 135 to 140 mph..... and then have 14 more turns to negotiate after that - lap after lap. Never needed anything other than my foot and I can stand the car on it's nose... I don't even run an aggressive pad. I prefer to buy cheap pads over Spec 37 rotors.
I have the bias set so when I'm threshold braking -- I know I've hit that point when the rears chatter (hop) and the ass is in the air and the nose is digging a hole - that way I know to let up just a bit.... it's a "telltale".
Old 10-17-2017, 04:45 PM
All good info.....
I had the Wilwood 15/16ths as you know and could not stop very well at 40 mph. I have another manual 15/16ths, new ready to go so I'm thinking that maybe try that first then Hydratech or bite the bullet now.
Old 10-17-2017, 06:09 PM
Hydratech®'s Avatar
Supporting Manufacturer
HydratechBraking.com
Smile Rule out your issues - install the other MC you have on hand
I do actually indeed suggest that you pop the other MC in to see what happens. It's already sitting there, so why not try it? I am a mega gearhead, and would definitely install the alternate MC myself to see what may happen before moving forward with anything else, especially as easy as it is to do a back to back MC swap out (providing you don't have to get into brake line port adapters or any changes with the brake lines).
TIP: Absolutely positively thoroughly bench bleed the MC first (off of the car literally in a bench vise, of course, right?) - view the links below. I strongly suggest the port plug method as opposed to the old school hose method for MC bench bleeding (it's vastly more conclusive than the hose method). Once that is done: Air does not go down brake lines when a MC is disconnected. As such, place a big fat towel underneath the MC to catch the brake fluid, disconnect the lines from your current MC, cap the brake lines with some generic vacuum caps for the moment. Yank the (dripping) current MC out (plug the ports quickly if possible to prevent the mess). Bolt the new MC in with the bleeding port plugs still in place. Now yank the little vacuum caps off of the brake lines and plug them into the new MC as quickly as you can, BUT do not tighten them down all of the way. Why? If you wait for both loosely connected lines to start steadily dripping, this has bled this part of the braking system out, not requiring you to get into a full on four wheel brake bleed session again (unless you believe there could be air still strapped somewhere in the system).
http://hydratechbraking.com/braketech1.html
http://www.hydratechbraking.com//ima...BleedSheet.JPG
Let us know how the alternate MC behaves - we're all here to help!
Founder / Master Engineer
Hydratech Braking Systems ®
Old 10-17-2017, 06:22 PM
Hydratech®'s Avatar
Post Major differences...
Street braking versus road course / track braking are definitely very very different scenarios. Track only / mostly? Fits Greg Welds comments, thoughts, and suggestions. Street use? That's a whole different world. Scrubbing off high speeds - say 150 down to 90 for a turn speaks more of the thermal capacity of the brakes. Street braking from 70 to zero is significantly different arena speaking much more so of instant clamping force available.
Here is a fun video:
Super Chevy Magazine exclaims, "In our history of vehicle testing, we have never had a car stop in this short of a distance!"
https://www.youtube.com/watch?time_c...&v=CpUy9wcAtJY
http://www.classicperform.com/Projec...rojectNova.htm
Old 10-18-2017, 04:05 PM
Paul what is the main difference between yours and CPP's Hydra stop? Thanks
Old 10-18-2017, 07:06 PM
Hydratech®'s Avatar
Thumbs down Damn - now you've hit a real sore spot with me (really pisses me off to no end)
Hi Kevin - man, this is like a "let's not even go there" topic - makes me so damn angry I am trying hard to stay calm and composed writing this post. As some know, and others unfortunately don't, CPP used to be a dealer of our systems years ago. We then discovered that they had started copying our systems - DOH! That discovery immediately led to us to cutting off supply to them, and then removing them as a dealer of our systems. This has actually been discovered as CPP's "Modus Operandi" also affecting MANY others in the aftermarket industry.
CPP even tried to order in one of everything Tobin at Kore3 produces so that they could copy his stuff too! Unreal...
https://en.wikipedia.org/wiki/Modus_operandi
*The CPP systems are cheap low end offshore copies.* Here is an e-mail I have circulated to some of our dealers:
BEWARE!!! Scroll all the way down and check out the link. Beware and watch out for the new Chinese crap hydroboost units hitting the market! CPP is using them, and Lord knows who else at this point. Apparently the patent rights must have run out and I’m sure Bosch is having conniption fits over this. We will continue to use genuine Bosch produced units regardless of how much this new flood of Chinese junk undercuts us… I need to find a way to identify the Chinese junk – casting differences or something we can point out to our customers so that they are aware. Tempted to have somebody order one in from CPP and have it shipped over here so that I can examine it – maybe just order one in from Atech / Summit… Check it out thoroughly and then just ship it back – yuck!
http://www.fiverbrakebooster.com/pro...er-Series.html
We have had many many confused customers calling us for tech support on what they thought were systems that we produced, finding in the conversations that they are actually dealing with a CPP "Hydro Stop" POS. The customers are shocked to find out that these are no longer Hydratech produced items, and despite all of this we still generally help them out best we can (despite this ugly scenario). They call complaining of improper assembly, parts not fitting, systems not operating properly. The other calls are how come I was at a car show and the guy parked next to me had a system that looked vastly better than my installed setup. Needless to say, we ask them did the other guys system say "HYDRATECH" on it? And what does your system say on it? They then get pissed off in the knowledge that they were somewhat hoodwinked into thinking that they were getting / have installed a Hydratech system. Some callers have also been really pissed off to find out that their "CPP Show Stopper" is just an unprepared / raw brake assist unit with nothing more than a chromed accumulator slip cover installed on the brake unit, a cheap copy of our billet firewall mounting plate, and one of their MCPV-1 MC's installed. So comparing apples to (rotten) apples, take a look at our three different levels of preparation for the details - you will clearly see that we do incredibly more with any level of preparation of our systems than anybody else in the industry using only genuine Bosch production brake assist units and only genuine high end Aeroquip power steering plumbing - scroll further down this web page to review:
http://www.hydratechbraking.com/products.html
While CPP has copied some of our systems, they have only copied a few of them. We have over 300+ highly specialized systems in our production line up. I can assure you that they do not have coverage for your factory manual brake C3 Vette...
Now off to mix up a Long Island Tea and calm down!
Old 10-18-2017, 04:41 PM
pm sent
Old 10-17-2017, 05:39 PM
All good info.....
I had the same set up on my car. It was great on the road course.
The street is a different ball game. Cold pads and way less friction.
Old 10-17-2017, 04:43 PM
Jim gave me a call and very helpful, thanks
