Old 06-07-2017, 03:34 PM
1970RT's Avatar
1970RT 1970RT is offline
Originally Posted by SBDave View Post
Very excited to see this build! ...and yeah it looks level
I've been called many things; among them, "picky".
David
Old 06-08-2017, 09:38 AM
1970RT's Avatar
We're going with the Magnum Force front end. Their transformer K member is a very nice piece of gear. Took a break from working on the rockers and got this installed.
Just need to finish out the motor mounts:
Factory stops removed:
Back to the rockers.
David
The Following User Says Thank You to 1970RT For This Useful Post:
syborg tt (10-28-2019)
  #33
Old 06-12-2017, 10:45 AM
chevelleshack chevelleshack is offline
Where did you get the 1/2 '' adjusters for the frame table ?
Old 06-13-2017, 02:36 PM
1970RT's Avatar
Amazon had a good deal:
Level-It - 1-7/8" Diameter Level Mount with 1/2-13 Threaded Stem https://www.amazon.com/dp/B0029MRUKK..._YOfqzbT35YM8F
Local stores only had 3/8 and smaller, which might have worked, but I didn't want to be weight limited to how much of the car I could assembled on the table.
David
Old 10-25-2017, 11:14 AM
1970RT's Avatar
After a summer of off-roading, hiking, and client projects, I have some time to work on the Charger again.
Rockers are open and trimmed and ready for internal reinforcement.
Rear section was chewed up pretty nicely my rust, and deformed at the pinch.
Bent up a repair plate.
Glad to be back working on it.
David
  #36
Old 10-25-2017, 03:08 PM
tubbed69's Avatar
tubbed69 tubbed69 is offline
Very nice work
Old 10-25-2017, 05:52 PM
It looks good, and that K member looks pretty stout.
Old 10-26-2017, 05:24 AM
1970RT's Avatar
Originally Posted by tubbed69 View Post
Very nice work
Thanks! I missed working on it.
Appreciate it, and yeah, I’m very pleased with the magnum force K member. It’s not really any lighter, but very rigid.
Some finishing details before welding.
For the mopar unibody nuts - this is the only taper, and there are no convoluted reliefs. Still plenty of room for the rear quarter to nest.
.023 wire is loaded. Let’s go to work.
David
  #39
Old 10-28-2017, 02:51 PM
1970RT's Avatar
Welded. Blended.
Now to make a cap.
David
  #40
Old 10-29-2017, 03:19 PM
1970RT's Avatar
Large day with family. This is about all I could manage to get done with the hour I had early this morning.
David
