Old 10-27-2017, 10:33 AM
1962nova's Avatar
1962nova 1962nova is offline
Originally Posted by will69camaro View Post
What is the rear tires. The 225/45 is slightly wider (10mm) and taller (9mm). The 235 is wider still but shorter than your existing tire by 5.5mm. All small differences so I'd see if you can fit the wider of the two options up front, and which has the better selection of tires available.
255/40 in a 17x8 got the rear
1962 Nova 2-door post. TCI IFS/4-link, 9" w/3.70, 383 w/ 579hp, 2004R......Almost done.
