Old 11-01-2017, 04:19 PM
vstol vstol is offline
Looks like I will need to make another fuel line since the new setup is in the pathway of the current set up. .
Old 11-01-2017, 06:36 PM
Hydratech®'s Avatar
Supporting Manufacturer
HydratechBraking.com
Arrow It's always something...
Back when I used to own Unlimited Racing in Detroit eons ago, we always had to discuss how one change always required other changes. Just installing a set of headers seemed simple to a customer, but always required further re-engineering to make it actually happen of everything around the headers. Sometimes a mini starter had to be installed, sometimes a double hump cross member, shorter spark plugs with different boot angles... Same with "just" installing a classic Holley carb - different fuel lines, different linkages, different air cleaner, jetting the carb, moving things around to accommodate the fuel bowls, and on and on and on...
Here is an image of a C2 Vette with an LS7 installed by https://www.streetshopinc.com/, showing how they chose to move the fuel line around the front of the hydraulic brake assist unit and master cylinder:
Hopefully you won't have to get too involved in re-engineering your fuel line!
Founder / Master Engineer
Hydratech Braking Systems ®
www.hydratechbraking.com
Old 11-02-2017, 03:01 AM
Thanks, I just need to put it together and measure but the C3 box comes out further thus pushing it very close to the Alternator. I think I will need to go under it
Old 11-02-2017, 05:34 PM
Hydratech®'s Avatar
Talking You are the artist ;)
You are the artist, and therefore the vehicle is your canvas.
Design the changes in the fuel line reconfiguration how you see fit as such. With a factory manual brake car, the brake lines are actually longer than the factory power brake C3's, so at least it ought to be easy for you to elegantly massage the brake lines into accommodating the factory power brake MC location further forward - usually the "big red EASY BUTTON" on that aspect. Have you received your replacement 1 1/8" bore MC yet? I'm hoping you can pound this bad boy down the road this weekend!
BTW - Your sign is AWESOME - JUST LOVE IT!
Semper Fi !
Old 11-03-2017, 02:59 AM
Semper Fi !
Thanks the MC came yesterday and the sign does get individuals attention. Remember there is nothing stock on this car except the body.
Old 11-03-2017, 05:50 PM
Hydratech®'s Avatar
Talking Stock body?
The body looks pretty heavily "massaged", so I wouldn't call it stock by any stretch! But is sure does look great - love the paint scheme.
Old 11-04-2017, 04:46 AM
true
