Old 11-23-2017, 07:27 PM
slenning's Avatar
slenning slenning is offline
I also got around to finishing mocking up the dash
The Fesler glass showed up!!!!
The windshield fit very well
The rear window not so much, but only by the quarters and after replacing and stretching them that wasn't too surprising
Steve
70 Camaro - in process https://lateral-g.net/forums/showthread.php4?t=50636
69 Camaro LS7/T56 https://lateral-g.net/members/lenning/
69 Camaro SS396/350hp
64 Chevelle - patiently waiting
2014 Z28 Ashen Gray
2010 Camaro 2SS/RS Black w/White stripes (wife's car)
2015 SS (the 4 door one) Wife's other car
Old 11-23-2017, 08:53 PM
Looking great. I like the exhaust clamp for tacking idea. Might have to steal that one.
Old 11-24-2017, 05:01 PM
Looks mean sitting on the ground, Steve. Congrats on making that milestone.
Old 11-25-2017, 08:24 AM
glassman's Avatar
glassman glassman is offline
Awesome as usual.
PM me regarding the back glass, i've got some suggestions if you do not want to go back to metal work. I did my own flush mount kit and have some data on the rear.
Can't wait to see it done.
Mike
The Following User Says Thank You to glassman For This Useful Post:
AB69Z (09-30-2018)
Old 11-25-2017, 11:03 AM
slenning's Avatar
Thanks, yeah the clamps worked real well especially when some of the pipes weren't perfectly round, mostly when cutting the elbows. Oh and I'm pretty sure I stole that idea from someone else
Thanks Trey! Those pics are actually from last November/December! I've got a lot of posting to get caught up on.
The work was going so slow earlier this year at the body shop I was starting to lose interest
Awesome as usual.
Thanks Mike, all of the metal work has been done for quite a while.
Steve
2014 Z28 Ashen Gray
Old 11-25-2017, 11:35 AM
slenning's Avatar
I should have explained better when the pics I posted were taken!! I received the Fesler glass in late November IIRC. I had the exhaust, brake and fuel lines done by the time the glass showed up. I got the IIMuch vents mounted and plumbed, and some other miscellaneous stuff done and the car went back to the body shop in early Feb. Also decided I didn't like the cowl area and stole an idea from John (Goosesdad)!! Thanks buddy!
Much better!!
The guy that was doing all of the carbon fiber fitting and glass work had a serious medical issue and missed a few months of work.
Random shots from the body shop mid summer
Then the shop moved into a new building first part of August.
Steve
2014 Z28 Ashen Gray
Old 11-25-2017, 11:54 AM
slenning's Avatar
I'd been trying to decide if I wanted to do some kind of venting in the hood. I liked the vent in the Z28 so much I bought one , got up the nerve to cut a hole in the hood we had already spent a ton of time getting to fit and.........
Made a cardboard pattern for a retainer to fasten the vent down from the underside, cut the actual piece out of 1/8 aluminum and rolled it to match the shape of the hood.
I decided I wanted to use Anvil inner fenderwells but they didn't fit the stretched fenders too well
So we cut the outer third or so off and rebuilt them with fiberglass to fit the fenders.
Cardboard backer in place
Cardboard ground away and adding more fiberglass
Finished product, painted the fiberglass areas black and then matte clear over everything.
We got some of the clear primer that Ringbrothers talked about in their carbon fiber video series and shot the hood and nose. Works very well for filling in pinholes and wet sanding the entire surface
Here's a shot of the bottom of the hood, had a lot of work to do on the outer area so painted that black, left the center carbon and then matte clear again over all of it
Steve
2014 Z28 Ashen Gray
